Old 04-30-2013, 09:05 PM   #1
Atomsplitter
Atomsplitter's Avatar
Steering wheel options? Retro look?
I picked up a nice steering wheel from a 50 Chevy Deluxe car and I was wondering if anyone else has swapped out the the OEM wheel for something old but interesting (not looking at going aftermarket or new).
I have a mid '80's streeing column and I'm not sure if the spline is the same throughout all those years, would I need to get a small stub from a 50 Chevy to weld onto the newer column?
Atomsplitter is offline   Reply With Quote
Old 04-30-2013, 09:24 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Steering wheel options? Retro look?
I'm no expert but I DON'T think you ever want to splice a steering column. And not a "stub" either. Not unless you're a certified welder and have the weld tested. At least I wouldn't want to.
Dan in Pasadena is offline   Reply With Quote
Old 04-30-2013, 09:35 PM   #3
NEWFISHER
NEWFISHER's Avatar
I just picked up a decent 57 Belair wheel with a new chrome horn ring at the swap meet last weekend. Plans are to repair a couple cracks, paint it and dress up the cab a little. I have a restored 3100 wheel and new horn button now, but they are just to plain to look at everyday.
NEWFISHER is offline   Reply With Quote
Old 04-30-2013, 10:36 PM   #4
Dan in Pasadena
Fish, I think our wheels can look great. Admittedly not as fancy as a Belair wheel but still quite nice:
Old 04-30-2013, 11:06 PM   #5
meter swinger
meter swinger's Avatar
I have a 62 impala wheel on mine. I picked it up from a friend who switched to a billet wheel. bolted right on.
meter swinger is offline   Reply With Quote
Old 04-30-2013, 11:35 PM   #6
NEWFISHER
NEWFISHER's Avatar
Dan, that's the later fancier wheel ( I call it the finned batwing) and they look awsome when two toned. I was also looking for one of those, but couldn't pass up the deal on the Belair.
Old 05-01-2013, 12:03 AM   #7
Dan in Pasadena
My truck is a 55.2 and has that wheel. Isn't mine and your '54 the same? I always thought they were.
Old 05-01-2013, 12:17 AM   #8
sqrlnts
Comon man you just bought a MIG, don't be scared!!!!
You could weld a sleeve around the OD of the two shafts then plug weld the sleeve to the two shaft parts. I have made a couple of these to extend the risers, never had a problem. Granted I had two risers attaching the handle bars to the bike but I didn't have a seat belt either!
sqrlnts is offline   Reply With Quote
Old 05-01-2013, 12:42 AM   #9
NEWFISHER
NEWFISHER's Avatar
Mines a 1950
Old 05-01-2013, 10:22 AM   #10
mknittle
mknittle's Avatar
I did the tie rod and the draglink on my jeep. does that count?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-01-2013, 11:11 AM   #11
mr48chev
mr48chev's Avatar
The wheel should go on the spline no problem but the column it's self may be too fat to look right with the early wheel.
My ongoing truck projects:
Old 05-01-2013, 11:32 AM   #12
skymangs
skymangs's Avatar
I used a 65 Chevy pickup column and an 83 Ford pickup wheel (15") I grafted my original 48 chevy center and spokes into it. Came out pretty trick, stock look only 3.5" smaller diameter.
skymangs is offline   Reply With Quote
Old 05-01-2013, 11:45 AM   #13
rollinrooster
rollinrooster's Avatar
Man.. that looks great!!!
rollinrooster is offline   Reply With Quote
Old 05-01-2013, 12:14 PM   #14
Dan in Pasadena
What did you use to replace the hard plastic/Bakelite? JB Weld? Or something else?
Old 05-01-2013, 12:50 PM   #15
sqrlnts
Man that looks perfect! How long did it take to do this work? Any links to the project? Thanks.
Old 05-01-2013, 03:18 PM   #16
OrrieG
OrrieG's Avatar
Here is a mock up photo of my 48 wheel on the 82 eldo column and the refurbished wheel. Not shown in the mockup is the eldo shelve that covers the part between the wheel and column. The metallic black does not photograph well, looks dusty! Do not have a final assembly pic yet. I used JB weld for the repairs, look at my build thread posts around 3/12 for details.
OrrieG is offline   Reply With Quote
Old 05-01-2013, 07:25 PM   #17
mknittle
mknittle's Avatar
That is what I was thinking!
Mark
My GMC build.
Old 05-01-2013, 07:27 PM   #18
OrrieG
OrrieG's Avatar
Hey, don't we all want a fatter column???
Old 05-01-2013, 07:30 PM   #19
mknittle
mknittle's Avatar
page 5 of of skymangs build thread.
http://67-72chevytrucks.com/vboard/s...=541904&page=5
Mark
My GMC build.
Old 05-02-2013, 11:11 AM   #20
skymangs
skymangs's Avatar
Thanks, Link is in my sig... Kinda runs throughout the build. I used POR-15 2 part epoxy (which is what steering wheel repair cats use). The steel core is of course welded to the new rim beneith the epoxy. If I had worked on it continuously, probably would have only taken a couple days. I waited 24 hrs. before sanding the epoxy each application of the epoxy.
Old 05-02-2013, 11:17 AM   #21
Dan in Pasadena
T.M.I. Orrie, T.M.I...
Old 05-02-2013, 11:54 AM   #22
mr48chev
mr48chev's Avatar
Not I said the old hot rodder. I've been there and done that and when one stands back and looks at his truck like I have he starts looking at things to see if they look like they appear as if they were designed for the truck or if they were stuck in the truck as an afterthought and don't really fit the theme of the truck.
I had a 74 Olds Cutlass tilt in my 48 for a number of years and while it worked great and was nice to be able to move the wheel up and down on road trips it just never looked right in the truck and always looked to fat and out of place. I'm going to run a 70 Chev truck column out of a four speed truck that my son had when it goes back together but haven't decided on the wheel yet. I love the Nardi wood wheel that is in my 71 but it won't look right in the 48 and the older larger diameter thin rimmed Nardi wheels are seriously expensive. I like the idea of putting a smaller but not too small rim on the old hub though and i have plenty of old wheels in so so shape to play with.
Old 05-02-2013, 02:25 PM   #23
Dan in Pasadena
Uh....maybe I just have a dirty mind, but I THINK Orrie was referring to another kind of "column"
Old 05-02-2013, 05:25 PM   #24
mknittle
mknittle's Avatar
That's what I thought too.
Mark
My GMC build.
Old 05-02-2013, 07:19 PM   #25
_Ogre
_Ogre's Avatar
nice steering wheel mod skymangs
dang... now i have to mod mine
shop air compressor timer
