Truck Died while driving
Was driving home today and the truck died when taking off. It turns over but doesnt start. I recently replace the ICM.
I'm leaning toward the electronic spark control module after some research. I put some gas in the carb and still didnt start. No spark. |
Junior Member
Re: Truck Died while driving
I think we may need a little more information about the truck and the engine to be able to help.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
1986 GMC Sierra 305 All stock
ESC is located behind glove box Posted via Mobile Device |
Swao to a reg dizzy to get away from that box. Had one on my 86 abd it messed up would run but no power. Coukd not even find a new box so I droped in a dizzy from a chevlle I had been 5 years with no probkems
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
i would say ignition module, in the distributor
"DON'T TOUCH THE TRIM!!"-Early Kyler |
When my truck died it turned out to be a module in the distributor but I forget the acronym (87 gmc v2500 w/350).
Posted via Mobile Device Last edited by Pano; 05-01-2013 at 04:49 AM. Reason: Spelling |
my 84 did same thing,i disconeted wireing harness at distributor put jumper wire from terminal a to terminal c and it started.it wont cost anything to try,good luck.
got info from 84 gm shop manual.
Changed out the Ignition Module and it started then died like it went out again....
What would cause it to go out that quick again??? |
look for loose or bare wires tht could be shorting it, also are the connections tight?
I say get rid of all that wiring and put a regular dizzy in it. Only thing that will be a pain is if you have the cali smog and a 700r4.
all hei distributors have an ignition module, do you want him to put points in it?
#13 |
BAD BOW-Silverado XST
He means, install an HEI without ESC connections. You can bypass the ESC if you don't want to remove wiring.
http://www.73-87.com/7387garage/drivetrain/escrepl.htm |
#14 | |
You can remove all that wiring without having to cut or modify your current wiring harness. The ESC crap is all stand alone wiring unless Like I said you have the Cali. smog crap and the 700r4 then its tied into that ESC box. Forgive my spelling and probably run on sentences I'm not the best at it but I try my best to help people even if I seem to ramble on and not make a whole lot of sense at times. |
#15 | |
#16 |
i still have jumper wire on mine,its been about five years now.allmost drove me nuts until i found out what was wrong.
#17 |
#18 |
I got it started... ICM
now it seems to be leaking around the carburetor linkage and also smells like something burning around carb. Like the carb is sucking for gas.. stump again |
