Old 04-30-2013, 11:56 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Brake Switch Wiring... Cool wiring pics!!!
Hey guys, its another Brake Switch wiring question.
Details - 77 c10, 5.3/4l60e swap. EZ21 wiring harness
Park Lights come on, but no brake lights... Wiring pic using four prong switch, and some pics of my project...
Orange Wire - Brake Switch Power
White Wire- Brake Switch
Red Wire - TCC wire PSI Harness
Pink Wire - 12V to battery
What am I doing wrong?
Name:  Brake Switch Wiring.jpg
Name:  Front in garage.jpg
Name:  Passenger Side in Garage 2.jpg
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 05-01-2013, 06:31 AM   #2
bigd65
bigd65's Avatar
Re: Brake Switch Wiring... Cool wiring pics!!!
I wish my garage was that clean
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 05-01-2013, 09:48 AM   #3
hatzie
Moderator
hatzie's Avatar
If your harness matches the Original... The white wire from the brake pedal should go to the steering column harmonica connector. From there into the turnsignal switch. The turnsignal switch feeds the bright filaments of the 1157 bulbs in the tails when the white wire from the brake pedal is hot.
Do the rear hazards and turnsignals work?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-01-2013, 12:22 PM   #4
JNJchev77
Registered Cruiser
JNJchev77's Avatar
The EZ Harness is a Universal Harness, so it's not an exact match.
The white wire and orange both come out of the harmonica connector, the white was considerably longer than the orange....?
Not sure about hazards, and my turn signal cam is broken, needs replaced. But when I turn the key, the right tail flashes, so I'm assuming the turn signals work...
77' Chevy SB
5.3/4l60e combo
Old 05-01-2013, 02:29 PM   #5
JNJchev77
Registered Cruiser
JNJchev77's Avatar
If you guys need more info, or better pics. Please let me know...
77' Chevy SB
5.3/4l60e combo
Old 05-01-2013, 06:34 PM   #6
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Can I get a Mods help and have this moved over to the electrical section? Hoping I can get some help over there... my apologies guys.
77' Chevy SB
5.3/4l60e combo
Old 05-01-2013, 10:12 PM   #7
ls1nova71
ls1nova71's Avatar
Have you unplugged the orange and white wires from the switch and jumped them together to see if they work? Do you actually have power on the orange wire? Checked the fuses?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-01-2013, 10:25 PM   #8
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I will jump them together... they are joined going into the plug on the column, if that helps. i'll check fuses too
77' Chevy SB
5.3/4l60e combo
Old 05-02-2013, 12:00 AM   #9
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks LS1nova... It was a blown fuse. Checked orange wire for power and nothing, fuse was toast. Got one brake light to work, the other doesn't work becasue my turn signal on that side is on and turn signal cam is broken, so need to replace that.... I'm hoping that is it. Posed my question in electrical so hopefully get some help there.
Thanks for your help fellas!
77' Chevy SB
5.3/4l60e combo
Old 05-02-2013, 09:09 AM   #10
hatzie
Moderator
hatzie's Avatar
Sounds like you fixed it. New AC Delco Turnsignal switches are still available.
If you look at the turnsignal switch detail in the 1977 GM wiring manual the pinout on the switch side of the harmonica will not be changed regardless of what harness you used.
Old 05-02-2013, 11:40 AM   #11
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks hatzie!
77' Chevy SB
5.3/4l60e combo
