How to remove the white lines on gauge lens
I am installing a camaro tach in my gauge cluster. And I am trying to remove the white lines on the lens where the tach will be. And I have already messed up one lens trying to get the lines off. So I am just hoping someone can tell me different ways to try and remove the lines. Thanks for any help you can give
1972 Cheyenne (Major Project) 1993 Jeep Wrangler 2012 Ford F150 FX2 2012 GMC Yukon |
#2 | |
Re: How to remove the white lines on gauge lens
Posted via Mobile Device |
Yea I am rubbing the right side of the lens. That Goof Off is hand cleaner right?
][/B]Posted via Mobile Device
It's alsways something.....
![]() Join Date: Nov 2008
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
mcguires has a product "PLASTIX" works great for polishing plastic lens and windshields etc that is what i'd use
Look for Novus Plastic polish, it's wonderful stuff. For heavy scratches you use Novus #3, light scratches Novus #2, and #1 is a glaze that will glaze over the last minor haze and give the surface a smooth glossy sheen. I've actually used it on plastic so bad that I had to sand and steel wool it first to get major deep scratches off and then polish with Novus 3, 2 then 1 and you'd think it was a new piece. Be warned though if you go to the extent of sanding it's very easy to distort the flatness or thickness of the piece and when it's a lens well it starts to distort the view of what is behind it. Anyway works great on acrylics, polycarbonate, styrene and even hard rubber parts and Bakelite type parts.
Got the lines off with some polishing compound. Thanks for all the info guys
![]() Join Date: Oct 2012
Goof off will mess up the plastic lens. If you use it, plan on polishing the lens afterwards.
Post some pictures of those gauges, I'd like to see what they look like! I've thought of doing the same thing myself.
#12 | |
![]() Join Date: Sep 2012
#13 |
Here is this finished product. With the cluster cover on and off
QUOTE=wgr2112;6050852]Post some pictures of those gauges, I'd like to see what they look like! I've thought of doing the same thing myself.[/QUOTE] Posted via Mobile Device
#14 |
Very nice!
I also thought about using the 150mph Z28 speedo. It looks like it bolts up the same as our unit. |
