Old 05-01-2013, 07:28 AM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Post One man truck box removal and reinstall (tuitorial)
Here's how you remove and reinstall a truck box all by yourself. I simply purchased an 8' piece of square tubing that fit inside my engine crane top arm. (a nice thick gauge 1/4+ so it won't sag) Remove the short arm that comes with the hoist and slide this one in it's place.
With a doubled up 2 X 4 positioned just forward of center on the box, center the tubing under the 2 X 4 (easy to do, just use the center rib in box floor as a guide) To distribute the weight a little better under the box top rail, I put 2 short pieces of 2 X 3 under the bed side rail. (you'll notice they are held in place by the clamps) After making sure you removed all the bed bolts and disconnect any wiring, start to slowly jack the box up to see how things look.
Odds are you won't be perfectly centered front to back and the box will lift more on one end but it's no problem. You don't even have to reposition the jack, just add a little weight to whatever end lifts first to balance it out. I used 2 wooden blocks I built that I use to stand on when doing engine work which have a good amount of weight to them. In this case, they worked out nicely. Anything you have around will work.
You'll know when you have the right weight as the box will level right out.
Once it's lifting level, raise the box slowly until it will clear the tires and bumper and simply drive the truck out from under it.
In my case I wasn't concerned about scratching paint but if you have nice paint, a piece of cardboard or foam insulation set between box and cab would be a very good idea. Also a little padding on bumper is a good idea as box will get VERY close to it.
Also notice I used 2 large C clamps to attach a block of wood on front and rear of the beam where it contacts the doubled 2 X 4. Just a precaution so nothing shifts around. I also have a C clamp at the back of the tube so it can't slip forward out of the hoist. It never hurts to be extra careful.
P.S. I also used this same engine hoist and 8' tube to lift a cab off of a frame although I had to add some weight to the back of the hoist as it tended to tip forward. An old V8 engine block worked to hold it down.
Please use this guide at your own risk. Use common sense and make all moves slowly & carefully without jerking the box around. Once box is lifted any amount, do not go under it! We want to see you again tomorrow...
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-01-2013, 07:53 AM   #2
KEL
72 GMC
KEL's Avatar
Re: One man truck box removal and reinstall (tuitorial)
Thanks !
It looks soooo easy when someone else is doing it.
KEL is offline   Reply With Quote
Old 05-01-2013, 07:57 AM   #3
WadmalawJoe
WadmalawJoe's Avatar
Excellent!
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 05-01-2013, 10:03 AM   #4
67chevemall
67chevemall's Avatar
Join the Group!!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-01-2013, 10:04 AM   #5
67chevemall
http://67-72chevytrucks.com/vboard/group.php?groupid=59
Old 05-01-2013, 10:41 AM   #6
domeier
domeier's Avatar
Clever. Very clever.
domeier is offline   Reply With Quote
Old 05-01-2013, 10:57 AM   #7
bollybib
bollybib's Avatar
Next time I try this I'm gonna make sure I have a crane on hand and do it like you did !
Instead of like this:
http://67-72chevytrucks.com/vboard/s...2&postcount=26
http://67-72chevytrucks.com/vboard/s...3&postcount=27
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 05-01-2013, 04:54 PM   #8
Southern Shaker
And this years Nobel Prize Goes to ...BOB!
Southern Shaker is offline   Reply With Quote
Old 05-01-2013, 05:25 PM   #9
TexasSteve
TexasSteve's Avatar
A tree limb or roof rafter works good too, if you have no engine lift. Very stable too.
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog
TexasSteve is offline   Reply With Quote
Old 05-01-2013, 08:12 PM   #10
ecgate
ecgate's Avatar
Do you have a one man cab removal tool also?
ecgate is offline   Reply With Quote
Old 05-01-2013, 09:12 PM   #11
CG
BlahBlahBlah
Originally Posted by 67chevemall View Post
This is hilarious ... do you guys have get togethers at the local chiropractor?
Old 05-02-2013, 06:35 AM   #12
bobs409
bobs409's Avatar
Funny you should ask.
The same "tools" do that too. Just make sure you extend the beam out enough so the legs of the hoist don't get in the way of the tires when you roll the frame out. (it's ok to turn the wheels a little on truck to clear)
Note the engine block and transmission on the back of the hoist. This was needed due to the beam being extended so far but worked perfectly. RED NECK INGENUITY!
"No cabs or boxes were harmed in the making of this guide"
Bob
Old 05-02-2013, 06:36 AM   #13
bobs409
bobs409's Avatar
Thumbs up Re: One man truck box removal and reinstall (tuitorial)
Thank you. I accept.
Bob
Old 05-02-2013, 08:13 AM   #14
RenoKeene
Florida Edition
RenoKeene's Avatar
Very well done! Tree limb and chain hoist works well also.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-02-2013, 10:15 AM   #15
cdowns
cdowns's Avatar
an "engine crane" ???
i have used for years // remove and install tailgate, doors ,hood, front clip ,cab, bed, frame an 80gallon compressor heck i even use it to lift motorcycles for service, lifting sandblast cabinet
imagination an understanding of balance and leverage will works wonders
Old 05-02-2013, 10:50 AM   #16
Vandy5
Vandy5's Avatar
awesome idea this will be coming in handy as i usually work by myself
Vandy5 is offline   Reply With Quote
Old 05-02-2013, 11:13 AM   #17
ole dollor
ole dollor's Avatar
yep that is a good way to do it by yourself...thanks for the info...save your back as long as you can.
ole dollor is offline   Reply With Quote
Old 05-02-2013, 01:39 PM   #18
Husker_Fan
Fantastic idea Bob.....thanks for sharing.
Husker_Fan is offline   Reply With Quote
Old 06-12-2013, 09:07 PM   #19
t300
Great idea! Out of curiosity any idea what a (long) box weighs? 350lbs or so? Just a wild guess
t300 is offline   Reply With Quote
Old 06-13-2013, 01:26 AM   #20
PAWS 72
PAWS 72's Avatar
Especially after 7 back surgeries.I know
PAWS 72 is offline   Reply With Quote
Old 06-13-2013, 10:47 AM   #21
Wasted Income
Boosted Member
Wasted Income's Avatar
Badass. That's a great idea.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-13-2013, 10:04 PM   #22
Leonard1
Leonard1's Avatar
Cool. I use the 4x4 method as well, except I put one crossways close to the front, and another at the rear, and run a 6 footer under both length wise with the bed. Then I just wrap a chain around the 6' and lift it with my hoist. It takes a couple of tries to get it balanced, but once you do the bed is very stable. It doesn't want to teeter as bad as using just one.
Leonard1 is offline   Reply With Quote
Old 08-29-2013, 08:26 PM   #23
swamp rat
swamp rat's Avatar
Nice!!!!!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-30-2013, 08:26 AM   #24
Keith Seymore
Keith Seymore's Avatar
Yep.
http://67-72chevytrucks.com/vboard/s...=342926&page=5
Mine was a shortbox, which probably allowed me to use the existing engine hoist tubing.
On earlier trucks we had a fifth wheel hitch, so we would just undo the box bolts and pick it up using the hitch.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-30-2013, 05:46 PM   #25
motorcritter
motorcritter's Avatar
Rolling it around on gravel!? Who needs a 'spa membership'?
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
