I need to know the best place to buy shock for the front of my 62, it is lowered in front.
1970 442 convertible 1970 Cutlass SX 1962 Chevy Stepside 2011 GMC 3500HD Crewcab SLT DRW |
Senior Enthusiast
Re: 62 Front Shocks
I’d suggest shopping for lowered shocks for a 63-85 truck which will have far more listings available. Pick whichever is your favorite. The only difference between the 60-62 front shocks and the 63-85 shocks is the steel sleeve in the upper rubber bushing. Just press the upper sleeve out of your 62 shocks and push it into the upper rubber bushing on the new shocks.
The steel sleeve is needed to keep the original 60-62 frame bracket from collapsing when tightened up. The later trucks use a shouldered stud instead to hold the correct spacing. This will give you a lot more options to pick from.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: 62 Front Shocks
great thanks!
Re: 62 Front Shocks
Before you buy new shocks, measure the front shocks from eye to eye. I just went through this and found out that my shocks were the issue of bottoming out. I had 1/4" of compression travel!
I do not know how many inches I have lowered it, but it's alot. Here is the thread: http://67-72chevytrucks.com/vboard/s...d.php?t=573266
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
#5 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: 62 Front Shocks
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
