Old 05-01-2013, 11:04 AM   #1
Slammed96
My 64 Project
Hey all, figured I would show off my project a bit, not the prettiest thing ever but she's still in the works.
How she sat when I brought her home, fixed a few odds and ends, biggest thing being new front fenders. Now I'm waiting on money and space before tearing into it.
The eventual plan is to get the body fixed up, swap the frame for the one out of the 66 roller I also have, and pop in a 5.3 and T56. May also go a bit lower with it as well
Slammed96 is offline   Reply With Quote
Old 05-03-2013, 07:36 PM   #2
kingsolver72
10/30/19
kingsolver72's Avatar
Re: My 64 Project
I really dig your truck. Nice stance.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 05-05-2013, 12:10 PM   #3
Slammed96
Re: My 64 Project
Thanks, think I may come down a bit in the front though. The huge fender gap bugs me. Second pic is a photoshop, inspiration to keep building.
14 Silverado- 4/6 drop daily
66 GMC short wide Custom Cab- building to be low and cruise. 283/t56 swap occurring now. Stupid low static drop
55.5 Chevy 3600 NAPCO 4X4.... not sure where I'll take this one...
Old 03-13-2017, 06:09 PM   #4
Slammed96
Re: My 64 Project
A little update on this project. Ended up trading the C10 for a 66 GMC short wide custom cab. Here are a few shots of the truck when I got it.
Pulled it out, cleaned it up, and threw some new wheels on it.
Old 03-13-2017, 06:22 PM   #5
Slammed96
Re: My 64 Project
Moved to a new place that has a garage, meaning the GMC could make it out of storage and progress could be made.
Started cleaning out the interior. The seats ended up in the trash.
Also swapped out the front fenders for some in better shape.
Old 03-13-2017, 06:45 PM   #6
Slammed96
Re: My 64 Project
Got some small stuff knocked out. Picked up a bumper and got it hung. Also found a new bulb for the headlight.
Swapped out the steering column for a nicer setup that i had laying around.
Old 03-13-2017, 06:49 PM   #7
Slammed96
Re: My 64 Project
reserve slot for more pictures.
Old 03-13-2017, 06:49 PM   #8
Slammed96
Re: My 64 Project
reserved
Old 03-13-2017, 10:50 PM   #9
Warrens69GMC
Warrens69GMC's Avatar
Re: My 64 Project
I think there is a 10 minute limit to edit the posts.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-06-2018, 10:36 AM   #10
Slammed96
Re: My 64 Project
Need to get this thread back up to speed. A lot has changed in a short time. Since the last update, got the front end updated with 73-87 a arms, drop spindles, and some lowering springs. The rear end got a flip and I also removed a few overload springs from the leaf pack.
Old 10-06-2018, 10:48 AM   #11
Slammed96
Re: My 64 Project
The engine and trans finally got set down in the truck, everything lines up and fits perfectly. Also went and picked up a donor parts truck for a few parts. Personally I think patina teal is the best color for these trucks.
Old 10-06-2018, 10:55 AM   #12
Slammed96
Re: My 64 Project
Moved the truck to a shop while moving to a new house and ended up losing out a ton of potential work time on it. I did build a new grille for it out of boredom, and got a few small odds and ends done when it returned home.
Old 10-06-2018, 11:06 AM   #13
Slammed96
Re: My 64 Project
Finally got her all together and had a chance to drive out to greaserama this fall. Sadly that was about all the road time she got. Currently the truck is back in the shop having some transmission issues worked out. Once it's done, plans are to replace the floors, raise the bed floor, and notch the rear end. Waiting for it to return while working on a high hump section for the cab.
Old 10-06-2018, 11:41 AM   #14
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: My 64 Project
Rad looking.
I really like the stance
66 C20 Service Truck:
Old 10-06-2018, 11:41 AM   #15
Lil Loafer
Re: My 64 Project
Sweet truck! I love mags on a lowered truck
Lil Loafer is offline   Reply With Quote
Old 10-06-2018, 11:58 AM   #16
Slammed96
Re: My 64 Project
Thanks guys! Really hoping I don't lose much of my rake when I notch the rear. The rockabilly hotrod look has kinda grown on me.
Old 10-07-2018, 11:31 AM   #17
Mack B
Mack B's Avatar
Re: My 64 Project
I love the stance! Do you mind sharing what size tires you have front and rear?
Mack B is offline   Reply With Quote
Old 10-07-2018, 11:53 AM   #18
Slammed96
Re: My 64 Project
Thanks man! They're 215/70/15s up front and 275/60/15s in the rear. I need to massage the rear fenders just a hair because they rub slightly, but otherwise they fit great.
Old 10-11-2018, 07:55 AM   #19
Slammed96
Re: My 64 Project
Picked up a pretty solid chevy cab from a few hours south of me the other day. The plan is to try and use the sheet metal I can, and attempt to repair some of the rust on my truck. Looking through a lot of build threads, I've noticed that about 90% of you guys are pulling the cab to do floor work. Am I in for a world of hurt if I try and do this with the cab still on the truck?
Old 10-11-2018, 09:32 AM   #20
63gm
Re: My 64 Project
I think it’s a lot easier to pull the cab but would depend how extensive the metal work is if your just changing a couple floor panels it’s probab not worth it. But if your like me and the floor was rotted along with most of the cab supports and rocker panels etc I would pull it just my opinion
63gm is offline   Reply With Quote
Old 10-11-2018, 09:35 AM   #21
Slammed96
Re: My 64 Project
My supports are surprisingly solid on here. I plan to pull the rockers and repair/replace them, as well as both footwells in the floor, and the trans tunnel. Otherwise the only real trick I've got is the cab corners. If I had to do supports I would definitely pull it.
Old 10-11-2018, 09:50 AM   #22
63gm
Re: My 64 Project
I don’t think I would pull it because all of that stuff is easily accessible without doing so. I’m putting my cab back together right now and I lift it off to get my supports in place but all the floor panels I have been welding in with the cab sitting on the frame I find it’s easier to line stuff back up with it on the frame especially if it’s possible keep the two rear cab bolts tight so the cab can’t move because it’s a bit of a job to realign it
Old 10-15-2018, 05:07 PM   #23
bigblazerboy
bigblazerboy's Avatar
Re: My 64 Project
what mounts did you use for the engine with the ls? i have a 66 lwb laying around i contemplate lq4 and t56 i have but found a swb im trying to see whats up. also thought the t56 shifter would be in the bench seat but it looks to actually fit perfect in your truck giving me ideas and modivation lol
1995 tahoe lt 4x4
http://www.cardomain.com/ride/3856942
bigblazerboy is offline   Reply With Quote
Old 10-15-2018, 07:06 PM   #24
Slammed96
Re: My 64 Project
I used the dirty dingo adjustable slider mounts for mine, fit like a glove! The t56 shifter will be in the seat in the stock location. I did a mid shift conversion on mine to get everything where it needs to be. The picture gives a good idea of how it moved the shifter.
Old 10-15-2018, 07:24 PM   #25
Slammed96
Re: My 64 Project
So I got bored while waiting for the gmc to get done in the shop and gutted the parts cab I picked up. Before anyone gets mad, it had no title and there was rot in the roof, so it went to a better place. Surprised how well it held up even with my cutting. Now the floor is ripe for the picking to be used in the gmc.
