Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-01-2013, 12:06 PM   #1
USMC45
Air/ Fuel ratio Wideband on Carbed motor?
First off here's a couple quick vids of the initial start up the other night.
http://i1099.photobucket.com/albums/...7C424D9FC6.mp4
http://i1099.photobucket.com/albums/...7FB1748FCA.mp4
It's a forged, dished pistons, H beam rods, 383 stroker with 9 to 1 compression. It's only gonna see about 6-8 psi of boost from the Vortech V3 supercharger on it. So my question is, do I need a Wideband? FAST makes one that does data logging and has (2) sensors for exhaust instead of (1) like the normal auto meter Wideband.
I also have a LS Turbo motor in my other truck and I know it's a must have in it but I have been told its not so important on Carbed motors.
Any help is greatly appreciated!
Under Construction* 2011 Chevrolet C1500 | RCSB | 6.7 | 10PSI
*Under Construction* 1968 Chevrolet C10 | SWB | 6.3 | 6PSI
*Under Construction* 1968 Dodge Coronet 440/ Cloned Super Bee | 7.2 | 14PSI
USMC45 is offline   Reply With Quote
Old 05-02-2013, 03:27 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Air/ Fuel ratio Wideband on Carbed motor?
First. narrowband O2 sensors are pretty much worthless. They fit in a stock EFI application where your just tweeking the cruise to best efficiency. But to tune for power, they don't provide anything useful.
I data log with a Innovate WB O2 in each header collector and EGT's sampled from 2 cylinders of both n/a carb's race motors. And quite frankly I don't know how you'd [i]accurately and correctly[i/] tune a carb'd application without the WB02. Go look on any real engine dyno and EGT's and WB O2 is standard equipment!
Reading plugs is only a indication of what a new the plug was subject to from startup to shutoff. (idle, run, transition, WOT and shutdown) ESPECIALLY is a forced induction of anykind I'd want to KNOW what a/f Im subjecting the motor to. But maybe that's just me.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-02-2013, 05:10 PM   #3
USMC45
Thanks for the input Marv. This is the one I am looking at getting, is this a good one or should I go with something else?
http://www.fuelairspark.com/fas/dyno...al-sensor.html
Old 05-03-2013, 06:57 PM   #4
Marv D
Marv D's Avatar
FAST is first rate equipment all the way!!! Kinda like Racpaak,, only thing not to like is the price. Unfortunately quality costs!
Old 05-03-2013, 11:51 PM   #5
Super73
Super73's Avatar
I ran an innovate, actually went through two. Was not impressed to say the least. Nothing but issues. Switched to and AEM and would never go back.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-04-2013, 11:54 AM   #6
Marv D
Marv D's Avatar
I'd have to agree Shaun.. I had a lot of issues with the Innovate at first. These last two LC-1 I bought seen to be OK so far... But the haven't been put to much test yet. **** keeps breaking
The Innovate stuff seems to work perfect in a lab setting, but the rigors of temp, vibration and voltage variation they see in the on-track racecar enviornment is another story all together. I sent 3 back and they sent them right back saying nothing was wrong with their equipment,, it was my wireing. Yeah well if I took my spare LC-1 and plugged it in to the exact same harness and it worked perfect, but 2 that came from Slummit and 1 replacement Innovate sent me wouldn't output to log.
Old 05-06-2013, 03:41 PM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
I'll weigh in as well...innovate is garbage in my experience. Been having really good luck with an AEM so far.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-07-2013, 03:58 PM   #8
nxtruck
nxtruck's Avatar
I use an AEM on mine, as well, and have had good luck with it so far.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 05-08-2013, 11:53 AM   #9
chevytruck1970
chevytruck1970's Avatar
Anyone using a wide band with methanol?
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 05-08-2013, 12:15 PM   #10
Rufton
My AEM analog wideband works great.
Much quicker than plug readings.
Rufton is offline   Reply With Quote
Old 05-08-2013, 06:16 PM   #11
USMC45
How many sensors is everybody running, Single or Dual?
Old 05-08-2013, 07:30 PM   #12
69GMC910
MOTORHEAD!
69GMC910's Avatar
What would be the advantage of two sensors on a carb'd motor?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 05-08-2013, 10:15 PM   #13
Rufton
Two would give you a heads up if there is an issue on one bank. I run one.
Old 05-09-2013, 09:42 AM   #14
Wasted Income
Boosted Member
I normally just run one, even when I was N/A. With the turbo, I just have one in the downpipe.
Yeah, for instance a bank that has a misfire on one or more holes will show more lean than the other side.
Turbo diesel
Old 05-09-2013, 10:00 PM   #15
Marv D
Marv D's Avatar
I run one in each header collector (n/a drag motors) But then I data log EGT's in 2 primaries and the 2 AFR's and oil temp and and and.. in a bracket class where 0.00x lights and 0.015 over your dial can = a loss,,, you need every bit of help being consistant as possible.
If your just looking to tune for best power and cruise efficienty and monitoring a gauge, I would think one would be as much as you can keep any eye on anyways.
Old 05-13-2013, 08:55 AM   #16
Hertzdaddy
You could always put a bung in each header and enough lead wire on the sensor to switch it around when you wanted. That way you could check if there were any initial problems and be prepared for any future issues.
Hertzdaddy is offline   Reply With Quote
Old 05-20-2013, 06:12 PM   #17
Billett
Billett's Avatar
I'm looking to do this exact thing with my lq4 swap. The Doug thorley headers already have o2 bungs welded in, so would I just get one normal o2 sensor and one wideband so I can swap them? I'm just learning about tuning and for the cost of a mail order and the normal set of o2 sensors it seems better to just get the software myself.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 05-21-2013, 01:42 PM   #18
Wasted Income
Boosted Member
I would get a plug for the "other" bank. O2 sensors don't like to be just hanging out in the exhaust without being powered up...they tend to die fast that way.
Turbo diesel
Old 05-21-2013, 04:07 PM   #19
Billett
Billett's Avatar
I meant a wideband that doubled as a narrow. That way I could run both at all times and swap sides for tuning. I suppose I could just plug one, but wouldn't I have to run in open loop all the time if I did that? I honestly have no idea what that is but from what I've read it isn't the preferred way to do things.
Will
2024 Toyota Sienna
Old 05-21-2013, 05:09 PM   #20
Wasted Income
Boosted Member
All i ever run is open loop....hence my opinion.
Turbo diesel
Old 05-22-2013, 12:19 PM   #21
Billett
Billett's Avatar
Do you still run a MAF or speed density? I plan on sticking with maf i was just curious. And I know you are turbo'd but in your opinion would running open loop bring down the mileage significantly? I realize these trucks aren't really built for mileage but if its only 1-2 mpg I don't care. If its more like 3-5 mpg less I might think otherwise
Will
2024 Toyota Sienna
Old 05-22-2013, 12:28 PM   #22
Hertzdaddy
My original post was in reference to a carbed motor. I would plug the unused bung in that case.
I gots no suggestions for you efi guys.
Old 05-22-2013, 04:19 PM   #23
Wasted Income
Boosted Member
I honestly don't give a **** about MPG. It's my fun toy. All I care about is going fast and making noise.
Turbo diesel
Old 05-31-2013, 04:08 PM   #24
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Daytona twin tech makes a kit ( I use it every time I dyno tune) and you can go out and log with it.. so you can a more stable look at whats going on.. NB sensor can be used however when you drop the MV down in the low 900 range the sensor is way far to one end, however a WB is a slower reading sensor than a NB.. Another thing you can so is figure how much a jet swap is giving you and use the NB down to 14.0 and then calc out the rest.. EGT is another way to get the job done..
GMR-PERFORMANCE is offline   Reply With Quote
