Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 05-01-2013, 04:12 PM   #1
drjeffdc
drjeffdc's Avatar
Fix or Fragment?
Motor knocking, ruled out flywheel, lifters, pushrods. timing gear had alot of slack but didn't look like it was rubbing on the cover.
drjeffdc is offline   Reply With Quote
Old 05-01-2013, 04:27 PM   #2
Kim57
Kim57's Avatar
Re: Fix or Fragment?
Looks like a real clean truck.
Replacement engines aren't all that much and would still be cheaper than a new truck in the long run.
If it were mine I'd probably rebuild what's in it if possible.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-01-2013, 04:49 PM   #3
vegadesign
vegadesign's Avatar
what kind of knock? can you determine how high or low its coming from??
loss of power?
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-03-2013, 09:54 AM   #4
drjeffdc
drjeffdc's Avatar
no loss of power, runs like bat outa hadies! faster RPM's faster the knock. won't do it at certain point of low rpm. hard to tell where it is coming from, almost sounds like a connecting rod. As wore as the timing chain was, it proberly just needs a new motor.
Old 05-03-2013, 10:21 AM   #5
vegadesign
vegadesign's Avatar
From an engin builder standpoint (scrap it)
Buy a new one or build one
You will pay more than a grand in just machining not even including parts
Old 05-17-2013, 10:48 AM   #6
drjeffdc
drjeffdc's Avatar
Sold it! One less project. Now I can focus on other things!
