Old 05-01-2013, 10:05 PM   #1
scottr55
gas odor
I wonder if someone has dealt with this problem. I have a 1964 C-10. The fuel tank is behind the seat. There is a gas odor in the cab and no leak is showing. The carb is also not leaking. Anyone have ideas on what I should check first, second, etc. ? Thanks. Scott
scottr55 is offline   Reply With Quote
Old 05-01-2013, 10:36 PM   #2
tincan1966
tincan1966's Avatar
Re: gas odor
Check the rubber hose in between the fuel tank and the filler neck- they have a tendency to dry out and crack.
tincan1966 is offline   Reply With Quote
Old 05-02-2013, 09:03 AM   #3
1963c-10
1963c-10's Avatar
Re: gas odor
And it is such a fun job too. They gave plenty of room to get lots of tools in. I almost think its easier to remove the tank to replace the filler hose than install in cab.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-02-2013, 09:37 AM   #4
scottr55
Re: gas odor
Thanks Tincan1966. That must be it cause the tank sending unit has a new gasket and shows no signs of leakage.
Thanks 1963C-10 for the heads up on the job difficulty. Not looking forward to it but it has to be done.
Scott
Old 05-02-2013, 10:58 AM   #5
Rich 5150 69
Rich 5150 69's Avatar
Re: gas odor
Filler cap seal, if it leaks when you`re making a right turn, it will seep out and past the outer body seal tube ring and back down in the cab is also a possibility.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
