Old 05-01-2013, 11:34 PM   #1
bugmasta
bugmasta's Avatar
Wheels spacers
I am going to have to add some 1" wheels spacers to the rear so to ensure I get right right ones, do you need to use hub centric spacers?
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 05-02-2013, 12:48 AM   #2
RManson
Re: Wheels spacers
I used these on the back of my '68...
http://www.tdperformance.com/Billet-...-Wheel-Spacers
They are 1 1/4" though. Not sure if that extra 1/4" will mess up your plans.
RManson is offline   Reply With Quote
Old 05-02-2013, 01:10 AM   #3
bugmasta
bugmasta's Avatar
Re: Wheels spacers
I think 1 1/4 would work fine. How did you decide on these? They seem about 2x as much as others I have found.
Not sure why I am having issues with spacing since I have a 72 wide rear end installed under my 68 but I am clearly having a clearance issue. So I have to do something.
Old 05-02-2013, 01:13 AM   #4
RManson
Re: Wheels spacers
They're the nicest I've found, plus they bolt to the axle, then the wheel bolts to it. Not a fan of the 'spacers' that squish between the wheel and axle and require longer studs.
What clearance problem are you having?
Old 05-02-2013, 01:22 AM   #5
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
Re: Wheels spacers
Got mine from lugnut king they are here in cali
and I picked them up at a local swap meet
looks like its the same set up only $100.00 cheaper
I see they have an account on ebay ...
good luck
JOHNORO is offline   Reply With Quote
Old 05-02-2013, 01:52 AM   #6
bugmasta
bugmasta's Avatar
Re: Wheels spacers
Ya, not looking for the squish kind, I want these bolt on kind. Here are some that I found that seem right
http://www.ezaccessory.com/Wheel_Ada...5500-5500p.htm
And these
http://billetwheeladapters.com/5-lug...-25-thick.html
I was mainly asking if there was something about the ones you chose that stood out as better since they are significantly more money. Not opposed to spending more if there is a justifiable reason.
Old 05-02-2013, 01:56 AM   #7
RManson
Re: Wheels spacers
Both of those look good. I especially like the option of the first with the different widths. Can't remember why I used what I did, could have just had them around or someone else 'round the office did. That happens alot, lol.
Old 05-02-2013, 02:02 AM   #8
bugmasta
bugmasta's Avatar
Re: Wheels spacers
Ya, I would like to find something local tomorrow so I can roll the new wheels for the show this weekend but if not will just order some and put them on for the next show.
Old 05-02-2013, 02:07 AM   #9
bugmasta
bugmasta's Avatar
Re: Wheels spacers
Here are some other too
http://www.ebay.com/itm/251199817212...=p5197.c0.m619
