Exhaust Routing
Hey friends,
Ya'll have probably been considering a new exhaust. I've got the opportunity to fix my own pipes and also make custom mufflers in stainless steel. Look at the drawing I have and say if im in the right direction. ![]() I'm thinking 2" pipes, and is there a need for a X or H? a H connection is more simple to do in this case.. The truck has a nearly standard SB 350 with headers. ![]() Please add your pictures!
Johnny G -----------Vehicles-------------- * Chevrolet C-10 Stepside 1962 * Audi A4 Avant Quattro TDI 2008 * Sachs Compact 50cc 1967 |
It's Better With Nitro
Re: Exhaust Routing
I like the planning. The exhaust will hang down pretty low to clear the transmission. The only suggestion I would have is to try and position the mufflers as far behind the cab as possible, because the noise and/or drone can get really annoying when the mufflers are positioned right under the cab. Here's how I routed my exhaust to keep the tubing at or above the bottom of the frame...
Re: Exhaust Routing
That looks really clean, Vin, I like it!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Re: Exhaust Routing
Vin,
Will you have enough clearance for your front wheels while turning? Maybe its just the angle of the photo. I like it and will consider this for our 61 build. glenn
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
#5 | |
Re: Exhaust Routing
#6 | |
Re: Exhaust Routing
Posted via Mobile Device Posted via Mobile Device
#7 | |
Re: Exhaust Routing
Swed, I pretty much did what you have drawn out for your truck. I used 2 1/4" all the way back with an "H" pipe just aft of the collectors. The Muff are Magna flow. I have a real nice "Header" sound and fairly quiet at the tail pipe unless I stomp on her. Cab is pretty quiet. ( I also used Dynamat in the cab) HAve fun!! |
Re: Exhaust Routing
I was planning on dumping my exhaust out the side in front of the rear wheels, but the exhaust shop said it is very hard on the rear wheels.
I'm now thinking of going through the trailing arm crossmember and over the axle, out the rear. You guys have issues with wheel corrosion? Posted via Mobile Device
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
Senior Enthusiast
Re: Exhaust Routing
I did. Many years ago I had a V8 54 Chevy sedan and dumped the exhaust right in front of the rear wheels. I thought it looked cool, but they needed constant cleaning and aluminum wheels really took a beating. I grew to hate the arrangement and have never done it again.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Senior Enthusiast
Re: Exhaust Routing
Here’s what my routing looks like. 2 ¼” pipes ending in turn downs just ahead of the rear axle. The H pipe dropped the exhaust sound by about 50%. Before the H pipe the mufflers really “barked” under full throttle. Now it sounds more like a 1960’s Corvette exhaust (at least to my untrained ear).
Re: Exhaust Routing
Markeb01, thanks for posting up those pics. I'm going to run my pipes the same, I like how the tailpipes aren't visible. What brand mufflers did you use?
Re: Exhaust Routing
turn downs aren't to popular at shows when parking with dust, ask me how i know---
1961 chevy K10 my build is------------61K10 build |
#13 | |
Senior Enthusiast
Re: Exhaust Routing
Without a balance tube, they are somewhat deep and mellow at idle, but really “bark” on full throttle. With a balance tube, the bark is gone and they sound more like an early Corvette to me. ![]() http://www.summitracing.com/parts/bi...1flt/overview/ ![]() And here’s how they sound under acceleration, about 1:39 into the video, although it's kind of hard to separate the exhaust from the engine inside the truck on a video:
#14 |
Re: Exhaust Routing
Thanks Swed for starting this thread! I've been trying to figure out what I am going to do with my exhaust too.
Mark, did you have any issues routing the exhaust into the back? |
#15 |
Re: Exhaust Routing
Markeb01, thanks alot for sharing! Looked at the summit link about length and I'm wondering about shortening my mufflers and put them where u have'em.
Maybe add another muffler to reduce more sound. I want to have a "dark sound". Posted via Mobile Device
#16 |
Re: Exhaust Routing
Thanks for posting up all that info Mark. Truck sounds good. I'm going to look into those mufflers.
Posted via Mobile Device |
#17 | |
Senior Enthusiast
Re: Exhaust Routing
These are the early pipes with the T bar crossmember in place, viewed from the rear: ![]() And after the xmbr was removed but before the new exhaust was installed, viewed from the front: ![]() It’s easy to see how much cleaner the routing was with the new exhaust.
#18 |
"Where were you in '62?"
![]() Join Date: Jul 2004
My exhaust at this time.
Will be re-doing it later with H-Pipe and the keeping the home made custom mufflers. PROJECT: "FULL METAL YELLOW JACKET Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=321173 Lets hear some different exhaust setups on your 1960 - 1966 Chevrolet & GMC Pickups http://67-72chevytrucks.com/vboard/s...d.php?t=526454 ![]() ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
| Bookmarks |
