Driveshafts
I'm in the process of mocking up things on my '53 3100, I have the Camaro rearend and SBC motor/350TH tranny mounted, next is the driveshaft. I know that whatever I choose probably will have to be altered, but this thing is going to be LONG. I've looked at the local pick-n-pull, nothing seems to be long enough. Any suggestions, besides a custom made one?
![]() Join Date: Apr 2010
Re: Driveshafts
I used a 2pc S10 4x4 shaft on mine. If you get a 2wd 2pc, you can mix and match front/rear shafts and it'll give you 3-4 inches of length difference. I'm running an S10 4x4 rear diff, with a SBC/TH350 combo as well.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
Re: Driveshafts
a 3100 one piece drive shaft is not that long
a 3200 or longer i'd look at 2 piece i'd go one piece for less complication quit looking at the fwd drive shafts ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: Driveshafts
I put a 350 with a short tailshaft th350 in mine I got the distributor as close to the firewall as could.
I'm using a 95 caprice drive shaft that's around 56" long (center to center on u-joints) It's a perfect fit with about 1 1/2" at the yoke. Can you put a yoke in the trans and pull it out about 1 1/2" then measure from the center of the u-joint to the center of the u-joint on the rearend? |
Re: Driveshafts
escalade 00 06 54 1/4 cntr to cntr 1310 to gm 3r conversion u joint for my 74 Camaro ten bolt and 1330 to gm 3r joint for th350 with a 7 inch yoke. measured yoke from cntr of u joint to end
