Old 05-02-2013, 01:11 PM   #1
Chevyllac
Chevyllac's Avatar
Water pump question
Morning fellas, I have a question about my water pump. What is a for sure way to tell if the water pump is on it's way out?? The truck does not over heat or leak but it does make a hissing noise up front how do I tell if it needs to be replaced?? or is it the belt that needs to be replaced?? thanks for any info
Chevyllac is offline   Reply With Quote
Old 05-02-2013, 01:33 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Water pump question
Might be the belt, put some belt dressing on the belt and see if the hissing goes away.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-02-2013, 01:45 PM   #3
domeier
domeier's Avatar
Get one of these: Nothing works better at isolating where weird noises are coming from. Never heard a water pump make a hissing noise. Are you sure it's not a vacuum leak, or maybe your radiator cap?
domeier is offline   Reply With Quote
Old 05-02-2013, 02:07 PM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I would look for something that is sucking air. The hose to my PVC came loose and it made a horrible hissing noise.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
