275/60, 15x10 and 2.5" spindles
This is my last thread about suspension and wheel/tire size, I swear..lol.
My '72 is originally a 6cyl truck, but has a built 350 now. I realize that springs sag overtime. If I install 2.5" drop spindles with my original springs, 4" drop in the rear, 275/60/15 tires mounted on 15x10" rallys with 4.5" back spacing, do you think I'll experience rubbage? Thank you for your support, Sid ![]()
1972 C/10 short step, 327/TH350, Blue Print H8002k Aluminum heads, 268 Lunati Voodoo cam, Lunati lifters, valve springs, roller rockers and Summit Racing dbl roller timing chain, Holley 670 Street Avenger dual line carb, Edelbrock RPM Air Gap intake, Summit ceramic coated long tube headers, Flowmasters, 3:73 gear, 15x10 Wheel Vintique Rallys w/ 295/50 front and rear, 2/4 drop, Custom Sound Head unit, Alpine amp, Fosgate Punch P3, Kenwood 6x9 in the doors, Grant GT w/tilt, B&M MegaShifter...etc |
![]() Join Date: Feb 2004
Re: 275/60, 15x10 and 2.5" spindles
You may have to trim a little i did but my tires probably balloon out more than yours. I have 15 x 12 w 6.5 bs. I really think you'll be ok but its iffy. You really are not that low tho. I have a full 9" drop in back and before the trim had about 1/2" each side on outter lip a delux trac bar may help you to keep the rear from shifting side to side more than the stocker.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
I just relized you truck is a 72 that means your rear is about an inch wider than mine aswell they changed mid 70 i believe i still dont think you will be tucked enough to have a problem tho,maybe with a load but you can see what mine looks like in aviator with 9"
Sid.....recall, I'm sporting 295/50/15x10 (4"bs) with ~6" rear drop. No rubbing. However! Rodznov11 brings up a good point about your axle length. You should take some measurements.
On the fronts I have 265/50/15x10 (4"bs) with 4.5 drop....no rubbing, not even close. I will be going to a 60 series in the front and I don't think I will have any clearance issues. BTW...Your new bumper looks great! ![]() Posted via Mobile Device
1970 C10 Short Stepper with 71/72 front clip. |
#5 | |
Thanks for the compliment on the bumper also. I talked to Dan today, but we were talking about his new truck he bought yesterday (Very Sharp 2013 Chevy) and I failed to ask if he still had the tailgate and rear bumper for sale. Gotta get wheels (rallys) and my drop kit first, but really hoping to snag that gate soon!
Sid...luckily when I put on the CPP 2.5" drop spindles the tie rod endS did not rub the wheel/rim. However if my back spacing was a little deeper...maybe 4.5" bs there would have been contact and I would have to do some grinding or change wheels bs or diameter. Take this into consideration. Early Classic's drop spindles may be configured as such that avoids this conflict. They should be able to advise you correctly.
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 05-03-2013 at 09:19 AM. Reason: Missing word |
#7 | |
