Glad I found this forum
I am a professional auto detailer and had a 2009 Ram that I kept the paint flawless on. However, people with classic show cars didn't see it as a show truck. It looked like I had just bought it new. So I sold it and bought a 1969 C10 2wd short bed step side. It has a 396 w/turbo 400. My first truck was a 69 C10 LWB so I know my way around them.
I'm gonna have lots of questions though. It has been switched to 5 lug and disc brakes on the front. I've never messed with lowering kits. Right now the truck sits over an inch lower on the driver's side. The front is 1-1/4" and the rear is over 1-1/2". It has some kind of kit on it but I have no idea on how to get it level. If I have to I'll buy a whole new kit including drop spindles. The bed also slopes down to the driver's side front corner. Anyway, if anyone has questions on detailing feel free to ask. Here is a link to the video of the truck when it was delivered. https://www.youtube.com/watch?v=3yQwVogVBwY Here are a couple of pics of my new ride. |
Re: Glad I found this forum
Nice truck, love them steppers.
Looks like a nice truck... I wish I started with one like that!
Gorgeous! Any idea what the seats are out of?
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Damn fine looking truck and welcome to the board from northwest florida
![]() Join Date: Feb 2003
wellcome from hot az
great looking truck!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
I am a Referee of life.
Nice truck!!Level may be hard to attain.There are tons of things that could throw it off.I would start by doing a thorough inspection of Body mounts,bushings,front suspension components and body alignment.There is so much slack in the factory specs that it could be off half that when new,but defining where the off is will get you a start.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
wwelcome to the forum we are glad you're here. Nice looking rig you have there.
![]() Join Date: Apr 2011
Wow that interior is fine. I'm not usually a fan of non-stock looks but that looks like you could just set back and cruise for hours.
Too bad you're not closer - if you could get my old beater to shine like that, I'd pay good money! LOL Welcome and good luck with your truck! |
MOVE OVER
welcome to the site ! I agree nice looking truck... might look at the "suspension" section on the board and post the same question...
No matter where you are..... There you are... Buckaroo Banzi |
welcome to the forum,, sounds liek yours has that good ol chevy tilt if its lower on the drivers side. dont know why they are like that but even newer chevy cars and trucks still have it
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
![]() Join Date: May 2012
Welcome to the forum from Texas, not to many of use get a starter truck that nice....yours is Real Nice....i like it a lot...
#13 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Also welcome from central Florida. If you want to figure it out start by unbolting all the shocks at the bottom, this will let you see if its a spring problem. Bounce it around a bit and let it settle then put a tape on it.
If the front springs are new check to make sure they are seated in the upper a-arms correctly.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#14 | |||||||||
WOW! What a welcome. You just don't get that on the other forums.
Thanks! I wanted a fleetside but this was too good a deal to pass up. Quote:
Thanks! From what others have said, they are out of a 2005 Chevy. Quote:
Thanks! Quote:
Here's a couple of pics of cars I have polished. |
#15 |
Very nice,,,
My build http://67-72chevytrucks.com/vboard/s...ar#post4724684 Posted via Mobile Device |
#16 |
when can you polish mine..those look great.
#17 |
Crimsom 69, I'm not to far from you. I'll Bring mine and let you practice buffing skills on it. Nice truck.
Welcome from Killen, Alabama. RTR |
#18 |
#19 |
![]() ![]() Join Date: Jan 2011
Sup buddy! Welcome from SE TN. You definitely have some skills!
I'm pretty sure what you're seeing is the infamous Chevy Lean. 85-90% of the trucks I have ever seen and/or lowered have experienced it. Pretty common thing actually. BUT -- one thing you might check is the way the front coil springs are seated into the lower control arms. If the truck has been lowered, there is a small indention in the lower control arm (there will be a tiny hole, it's there for a drain hole) the end of the coil spring needs to index into that pocket. Lets say it's correct on the drivers side but incorrect on the pass side (?) Maybe .. ? That would cause the difference you're describing. There's a good 1/2 turn in that coil spring and it may just be sitting a little high on the pass side if it's not down into that index properly. Can you pull some measurements for us from the center of the fender well arch to the ground on all 4 corners? Maybe take a few more pictures of it? We LOVE pictures. ![]()
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
