Old 05-02-2013, 03:37 PM   #1
truckdude239
truckdude239's Avatar
exhaust manifolds?
what clears the mounts on a 71 c-10 with the dirty dingo adjustable slider mounts? the factor truck manifolds did not clear
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-02-2013, 04:09 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: exhaust manifolds?
2010+ Camaro SS manifolds will..
Hart_Rod is offline   Reply With Quote
Old 05-02-2013, 07:40 PM   #3
truckdude239
so http://www.ebay.com/itm/Pacesetter-E...fddba0&vxp=mtr should fit
David fuller
2000 Tahoe 5.3l 378
Old 05-02-2013, 09:36 PM   #4
Daaaanz67
I'm using these with 73 stands coated inside out should have no problems with your stands fit tight
Daaaanz67 is offline   Reply With Quote
Old 05-02-2013, 09:40 PM   #5
truckdude239
What's the number on those?
David fuller
2000 Tahoe 5.3l 378
Old 05-02-2013, 10:17 PM   #6
Daaaanz67
310 delivered to Cali from josh at ky turbo their right up the road from Holley hooker cheaper than summit and got an actual deliver date where summit couldn't give me one. Really love the way the fit no stupid turns on the exit end.
Old 05-02-2013, 10:18 PM   #7
truckdude239
Do you know the part number?
David fuller
2000 Tahoe 5.3l 378
Old 05-03-2013, 09:41 AM   #8
Daaaanz67
No just told josh what I was looking for you could just look at summit racing web site and get an idea. Plus i think factory part # would be different to anyone else. Just a word of advice mine are black ceramic and ended up turning a slight gray if your interested in that color. I'll try To find the paper work.
Old 05-03-2013, 09:57 AM   #9
Hart_Rod
Hart_Rod's Avatar
Those are nice! Any idea how well they flow? Wonder if they would work well on a 6.2 with huffer?
Old 05-03-2013, 03:39 PM   #10
Daaaanz67
I think Holley actually rates these at around 550 horsepower. I've never seen documentation as far as testing by independent shops. My opinion which really doesn't matter to anyone are seem to be quality made super smooth finish inside with no excess casting flash also outside coated inside out runners flow smoothly into the main. Everything just appears to flow so nice. They dump out the bottom nicely with no funny angles. Would not hesitate to buy another set.
Old 05-03-2013, 03:49 PM   #11
AMERICAN PICK-UP
i have a lot of customers that are using. 98-02 f body manifolds, they work well.
AMERICAN PICK-UP is offline   Reply With Quote
Old 05-03-2013, 10:15 PM   #12
Ranger6202
GM f-bodies are the way to go. The hooker ones are too expensive, where you can get the f-body ones for about $100 cheaper online through GM. From what i could tell, they're close to the same contour too, with a little difference in the angle of the flanges.
Ranger6202 is offline   Reply With Quote
Old 05-03-2013, 10:18 PM   #13
Ranger6202
On the first page of my build, i put up a bunch of pics of how the F-bodies fit compared to the stockers. http://67-72chevytrucks.com/vboard/s...d.php?t=504827
Old 05-03-2013, 11:30 PM   #14
Daaaanz67
I agree with the camaros. Don't really care for the sheet metal look so I would have remove them then would have to grind the mounting points then the ceramic coating was another $100 plus the gas to the ceramic shop was 45 minutes away trust me I went back and forth between mine Doug thorley $415.00 headers and camaros this was most logical for look and performance.
Old 05-05-2013, 09:53 AM   #15
AMERICAN PICK-UP
you can buy all of the used ones that you want for $75.00 to $100.00 a set on www.ls1tech.com all kinds of them for sale on that site.
Old 05-05-2013, 02:10 PM   #16
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I'm using TBSS Manifolds, the hug the block nicely and are about $60-$70 a piece.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 05-05-2013, 05:51 PM   #17
Indian113
Indian113's Avatar
I have a set of 99 Camaro manifolds with O2 sensors I'm going to list in the 4 sale section. I bought them and had to buy headers when I put my 5.3 in my S10. I was wondering what they might be worth.
Indian113 is offline   Reply With Quote
