gas feed cable
can anybody tell me what kind of gas feed cable to use i have tride a 26 in, and loop it but it was hard to push what is everbody using
Re: gas feed cable
I've always gone to the wrecking yard with my tape measure and started sticking my head under the hoods of early 70's to mid 80's rear wheel drive GM car until I found something that would work. It still has to match your pedal and what ever fitting is on the carb if that fitting isn't removable. It also has to work with the pedal you are using That is unless you spent real money and bought an aftermarket pedal and cable.
Re: gas feed cable
One word LOKAR
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
Re: gas feed cable
Three words "mid 70's truck"; inspiration for after market designs. I sold both my 74 donors to rodders.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: gas feed cable
The Lokar ones work great as they are cut to fitand you can fine tune it perfectly.
Re: gas feed cable
You might try one of these. You can cut it to the length you need. http://www.ebay.com/itm/Mr-Gasket-56...fbc229&vxp=mtr
Search EBay and you can find the same thing even cheaper. |
Re: gas feed cable
thanks everbody for all the help
![]() Join Date: Aug 2010
Re: gas feed cable
Using a Lokar thru floor gas pedal and you want a stock looking pedal ?
Take a stock TF pedal and with a slight mod to the back side (grind off the rubber hump) and it slips over the Lokar pedal. Now screw, glue (silicone dabs) or rivet it to the Lokar pedal.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
Re: gas feed cable
G&R, have you done that? That's exactly what I am intending to do. I picked up a used Lokar thru floor pedal at a swap meet this past February and I have a new original style accelerator pedal that I intend to adapt to it. I'd like to see some pics if you have done it already.
Re: gas feed cable
I've got the pedals and put them together. I'm a long way from installing them on my truck.
A friend of mine was complaining about getting a hot foot (likes to drive bare foot)from his Lokar pedal, so I grabbed my parts ( NOT those parts ![]()
