wont fire with ne plug wires... help!
i installed some new 8mm plug wires on my 327 today and now it wont fire, i have checked the order time and time again and it is correct, engine will turn over great but will not fire, could i have fired the coil?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Re: wont fire with ne plug wires... help!
have you checked to see if you are getting spark at all out of the boots? If not, check coil.
havent checked that yet. it ran fine before i replaced them but the wires were in bad shape, i did them one by one trying to keep the order rite and it fired but ran like crap. i checked the order and had to swap a few but now nothing, it is and HEI if that helps
![]() Join Date: May 2012
Make sure your spark plugs are dry The same thing happen to me. My spark plugs were too wet and weren't firing I have a spark plug blaster so I clean all the fuel off of them and it started right up. Hope it helps
Posted via Mobile Device |
i have found that when tryin to check for proper sparkplug order it is best to remove all of them and start new with a service manual in hand and install them again one at a time/// i have found lookin at them and checkin just gave me a headache and accomplishid little, i wood keeep starin and not seein
perhaps when you were fooling with the wires you pulled the coil wire from the cap chech it too make sure you got contact
on another note my kid just put wires on his truck and a very short trip later the coil went bad...i didnt understand it but it happened....another coil an it ran great?????
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#7 | |
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
I pulled a plug to test spark and it has great spark
Have someone crank it while you run a timing light, and see where # 1 fires on the damper. Also, pull the cap with # 1 at TDC and see where the rotor is aimed. HEI's are nice, 'cause you can set up the cables from wherever #1 is. Hope you sort it out, it sucks to have a machine ready to go, and it won't go!
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
