tailgate interchange?
I See In Some Catalogs A Blazer Tailgate Is The Same From 73-91, While Others Show 73-77 And 78-Up. Will A Newer Tailgate Bolt On Without Any Issues Onto My 73? My Tailgate Has A Rip In The Steel On The Top Lip In The Center, And Want To Make Sure I Find One That Will Work
Also, What Causes These To Rip Like This, So I Can Avoid Having It Happen Again? Posted via Mobile Device |
Re: tailgate interchange?
Yes, they are all interchangeable. You can also swap a pickup tail gate on.
The blazer gates often rip at the corners, this is due to the window components being attached mainly to the outer skin and flexing over time fatigues the metal, short of not driving it there isn't much I know of that would stop it from happening again. |
I would be pretty sure they are all the same too. I put a gate off of an 85 on my 77 with no issues if that helps dispell any of the rumors about the break in years you list.
#4 | |
Thank You. Just Wanted To Make Sure, Since Finding A Clean Tailgate Is Easier From The Newer years
The difference is in the skin. GM put a rib across the upper portion that wasn't on the early K/5s. Pickup gates can be "made" to work on a K/5 with a soft top that doesn't use the glass. I have the rare '73 GMC gate I was going to put on my '85 Jimmy with soft top
#7 | |
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
It looks like I will be keeping the one I have and adding reinforcement plates along the entire top. Thank you guys for the info
