front inner fenderwells with airbags...
Gonna be installing air ride on my truck. Motor/tranny are coming out first, im gonna paint the engine compartment /firewall. Since im gonna be in there I was debating if I should just remove the inner fenderwells while im in there. From the looks of things it looks as though the stock fenderwells wouldnt allow the truck to go all the way down with bags or be driven really low. Are they pretty easy to remove??
Im guessing I may have to widen and add some height to the rear fenderwells in the bed too. Posted via Mobile Device |
Re: front inner fenderwells with airbags...
Hills rod and customs has them for the front and rear. Look in the suspension market place.
It depends on the tire size.
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=534956 |
I am a Referee of life.
How low do you want to go?What size tire?If you want to go low or lay frame or if you're gonna run 20's you probably need to take them out.If the truck hasn't been redone,the pass side inner probably needs to be replaced and maybe the core support repaired/replaced for structural strength.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Got the inner fenderwells removed today. Im still on the fence what wheel/tire size ill run so I figured just will run no inners for the time being. That way it wont matter.
Im planning on it being as low as I can go. Posted via Mobile Device |
