Anyone use a March Perf. serpantine system ?
Thinking about going with March Sport track Ultra for my build...wondering if anyone has used this system if so....,I would sure appreciate some pics above and from the side.The link to this system is below.
http://www.marchperf.com/sporttrack_clear-sb.html I hope I can run a short water pump to accommodate this set up along with my Vortec heads. Thoughts anyone ? I'm concerned about spacing as my rad is mounted pretty tight to the rad support. I will be running a flex fan and want to get inside the shroud for the best possible cooling. Thanks in advance, Ed. ![]()
Always a place in my heart for old Chevy trucks ![]() My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
![]() Join Date: Jan 2008
Re: Anyone use a March Perf. serpantine system ?
I have not used this exact system but I have used one for a sbc and a couple for my bbc's. My experience is the products are well made, everything has fit nice (as long as you mock it up without tightening untill all is in place). In some kits for BBC's I had a few issues with what they say you install first over what I actually had to install first but that maybe an ease factor.. what might be easy for some may not be for others.. Over all not a bad way to go if you are looking for a fancy look and have the money to spend. In my past exp with them the tech support and knowledge was good so call and ask and you should get all the answers ya need before ya buy.
Reid |
FWIW: I bought a set of march pulleys for car and they are nice.
