oil pressure light on-question
68 c10, 250 six
I fired my truck up today after it sat for the past two days. The last time I drove it, it gave me no problems. Today, as soon as I turned it on, the oil pressure light came on. I turned it off and checked the oil, which was full. No leaks or puddles. I then drove through the neighborhood and noticed it was running a little rough, so I took it home. If I revved the motor, the light would dim in relation to the RPM. It has rained a lot in the last two days, and the truck has been outside if that makes any difference. My thought is to check the pressure with a mechanical gauge tomorrow, and replace the oil pressure sending unit, but I wanted to see if anyone had any ideas on other things to check. Thanks fellas. |
Re: oil pressure light on-question
Yes definitely do that and before you check it with a mechanical gauge crank it over to be sure no sludge has plugged the passage to the sending unit which will give a false reading.
So pull the sensor (I think I found it...right next to the starter on the block with a single wire?) then fire it up and see what comes out?
Just make sure oil comes out then install your gauge to check it .
Who Changed This?
![]() Join Date: Jan 2013
It's going to puke oil all over if you do that! Pulling the sender off should allow oil to drip out. Peek in there and clean it with a wire or something if there is sludge built up there. Then put a gauge on it.
I usually don't try to clean it with a wire or anything as you can further lodge debri in the passage
i had the same problem with my 250 and the sending line was pluged up
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
Better replace oil filter before starting again.
If new oil filter solves pressure problem then expect to see metal flakes from bearings inside removed oil filter. Good luck and I hope it was sending unit not plugged filter. |
Well, finally did the oil change after a weekend of nothing but rain and everything looked good, so I replaced the pressure switch. All is now well with that...thanks guys.
NOW I fired it up and let her come up to temp, and the water outlet cracked in half. D'oh! I have a 195* thermostat in there. I also noticed the vacuum advance hose wasn't connected ![]() |
I run a 180 and no temp gauge lol
Truck runs super cool even with the clutch fan and the tiniest fan shroud ever Posted via Mobile Device
Haha yeah, no fan shroud here...i do have a 160 tstat at the house, but i think that's too cool
Posted via Mobile Device |
I run 195F T-stats and no fan shrouds.
#13 |
If you've seen the stock fan shroud for mine in like putting foil over the fan to prevent fingers
