Old 05-03-2013, 11:45 PM   #1
izzy_Britton
izzy_Britton's Avatar
Cruise Control Surging
I just purchased an 86 single cab SWB 305/700r4 cream puff, 81,000 original miles.
She has been sitting for at least 5 years i am thinking closer to 7 years. I just got it smogged, passed with flying colors. All of the vacuum lines were checked by the smog tech and everything was plugged in as it should be. all the lines look good and there is no dry rotting or visible cracking. I have tested MOST of the vacuum lines to check for leaks using starter fluid or brake parts cleaner, and everything seems 100%.
To the issue:
While driving down the freeway at 70ish MPH, when the cruise control is engaged the speed seem to remain pretty constant at the set speed. However the issue is two fold. While at speed and holding, the truck surges or lurches enough that it can be felt and is quite annoying. the second part is that after several miles. say 3-4 miles, the speed slowly starts to decrease. stepping on the throttle pedal slightly will kick the trans down a gear and the truck will take off again until it reaches the set speed and the whole cycle begins again.
for giggles this past weekend, I set cruise at 70, and didnt touch the throttle pedal for about 30 miles. the speed decreased to an unsafe speed and i exited the freeway around 40 MPH. Once on the off ramp i stabbed the throttle pedal quickly once and it took off to gain speed again but i had to stop at the sign at the top of the ramp.
There is a vacuum line going to the vacuum pot on the left inner fender well, it is intact. what else controls the cruise control function?
this is the 38th c/k truck i have owned in the past 20+ years. this is the only one that has/had a functioning cruise control.
Any words of wisdom would be greatly appreciated. Thanks in Advance
Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-04-2013, 10:03 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Cruise Control Surging
Vacuum leaks... at the brake pedal switch or the servo diaphragm??
The 1968-1998 GM Cruise Control training and service manuals are in my sig. The 84 Cruise III manual will give you troubleshooting detail.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-08-2013, 12:56 AM   #3
izzy_Britton
Thank you Sir!
I will delve deeper into this in the coming week. I now have a start and thank you for the manuals. much help.
-Izzy
