Old 05-04-2013, 12:33 AM   #1
whyte noize
whyte noize's Avatar
Dome Light Problem
My dome light inside the cab randomly came on and won't turn off. I disconnected the battery and when I reconnected it the dome light was still on. Any advice would be appreciated! My truck is a '86 if that matters.
whyte noize is offline   Reply With Quote
Old 05-04-2013, 04:49 AM   #2
naphtali5725
naphtali5725's Avatar
Re: Dome Light Problem
could be many things... may be the door switches.
not sure of your skill level so maybe the best thing to do is get familiar with the wiring diagrams of your truck? particularly with the inside of the cab...
you can go here:
http://www.2heeldrive.com/Chevrolet/...ng_Diagrams%2F
if your's is an 86 it is probably in 81up Chevy directory
http://www.2heeldrive.com/Chevrolet/...F81up+Chevy%2F
some of these are huge files, so it would be best to download them to your computer then open them up for easier viewing.
Not sure but maybe you could start with the file of the complete wiring manual 1986_GM_CK_Light_Truck_Wiring_Manual_S.pdf
http://www.2heeldrive.com/Chevrolet/...g_Manual_S.pdf
that's my suggestion, there will be others who will help
good luck
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-04-2013, 05:25 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Hi
done any other recent electrical work?
check and pull your door pins
white wire from doors to ground makes it come on
it runs across under the lip of the glove box
there are metal clips holding it
check it for nicks/ cuts
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-04-2013, 10:43 AM   #4
bilfman
bilfman's Avatar
I would check, adjust and clean the door striker switches. Remember + (hot) runs continuously to them . The striker makes the ground when the door is open. Once cleaned up try screwing them out a turn.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-04-2013, 11:47 AM   #5
whyte noize
Thanks for the help fella's! I have not done any electrical work at all recently. I'm not too familiar with electrical work, but I have a few friends that can help me troubleshoot with your suggestions. I'll check back soon!
Old 05-05-2013, 11:02 AM   #6
hatzie
Moderator
hatzie's Avatar
PDFs of the GM squarebody wiring and service manuals are in my signature.
The dome and courtesy lights have a hot direct to the fuse panel all the time. The door and headlight switch ground the other side of the bulb to the cab.
This is a fair representation of a GM dome light circuit.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-05-2013, 06:35 PM   #7
tucsonjwt
Carefully remove each door switch. You have to hold on to the center pin with small vice grips or pliers and turn the nut out. If you don't use this method you will just twist the switch around in the hole. Gently pull the switch out of the door pillar and see if the wires are OK (not frayed, still intact in the switch). You can put an alligator clip on the switch and to the hole in the door pillar and operate the plunger. If you get intermittent operation, replace the switch - available cheap at any parts store. My driver's door switch will not come on periodically, then work properly on occasion - fiddle with the door switch and it works properly.
tucsonjwt is offline   Reply With Quote
