Old 05-04-2013, 10:18 AM   #1
UATahoe
Seal material around evaporator tubes???
Replacing my evaporator, what do you guys normally use to seal up the casing where the evap tubes exit the case?
UATahoe is offline   Reply With Quote
Old 05-04-2013, 11:57 AM   #2
cfan10
cfan10's Avatar
Re: Seal material around evaporator tubes???
Having the same issue with mine, was considering using rtv if I can't locate the correct product.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 05-04-2013, 03:17 PM   #3
drew86
drew86's Avatar
I used some cork insulation tape I got from the hardware store.The company name is diversitech.Its used for plumbing ,and looks oem.
drew86 is offline   Reply With Quote
Old 05-04-2013, 08:23 PM   #4
UATahoe
Found the solution at advance auto parts. It's a roll of thin sticky tar type stuff. Made by factory air I believe and worked amazing. I will snap some pictures and get you the part number. It was super easy to use and it sealed up perfectly.
Old 05-04-2013, 11:57 PM   #5
bilfman
bilfman's Avatar
I found nearly the exact stuff. It is electrical duct seal made by Ideal industries. It's cheap and works just like the oem stuff. About $5 for enough for several projects. Just google " ideal industries duct seal"
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-05-2013, 12:34 AM   #6
Psycho_SWB
3M Strip Calk. Eastwood also sells their brand of Strip Calk.
Psycho_SWB is offline   Reply With Quote
Old 05-05-2013, 08:07 AM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
x2 that's what I used
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 05-05-2013, 08:16 AM   #8
homemade87
I used the same stuff as bilfman. I got it at the local lumber yard. It comes in a square block and it is grey. This works great if you don't find the other stuff.
homemade87 is offline   Reply With Quote
