70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Factory Vacumn Gauge Question
Could someone with a original factory vacumn gauge in their truck post a pic of where it comes through the firewall and where it is connected to the vacumn source on the motor. Thanks..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Factory Vacumn Gauge Question
what type truck r u lookin for
1/2 and 3/4ton trucks there was no vac gauge as an option/// was only on large commercial type trucks
#3 | |
C10 Long box with a 396 in it.
Well, maybe someone will post how they set up their vacuum gauge anyway.
I want to add a tach, vacuum and a clock, but only have two holes to work with. So,I may have to pass on the cool old clock. ![]()
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
Old member
I would pass on the vacum gauge since it doesn't do anything for you other than look good. The gauge itself isn't made for the engine vacume like the newer styles that help with gas mileage. It was for the brakes on the bigger trucks. I would go with the clock myself.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6 | |
#7 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Moderator
![]() Join Date: May 2007
Here is a pic of the factory hard line that was used. The left side connects to the back of the vacuum gauge. The right side connects to a vacuum source inside the engine compartment against the firewall. However you decide to route it, you need a hard line as a rubber line will collapse under vacuum.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Thanks for the info and advice Leddzepp. Here are pics of my dash. It was hard not to get any reflections on the clear faces of the gauges.
That is some nice gauges!
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
![]() Join Date: Oct 2009
that looks great greg, lookin fwd to seein it in the truck.
I'm looking forward to the work of installing it.
#13 |
Moderator
Good luck Greg! Here is a pic of my dash. All original parts, except for the aftermarket woodgrain bezel.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
#14 |
Moderator
Back
#15 |
Moderator
Andy is correct in that the vacuum gauge was not an option on C-10/30 trucks. The vacuum source is also tapped into the brake booster at the firewall on the larger trucks. The factory gauge also has hatch marks and numbers to read very easily. The numbers are standard, and end at 30, as does every vacuum gauge to my knowledge. It is very useful if it is actually hooked up rather than occupying space as an ornament (which in a lot of cases, it is). A clock is also a viable option, fills the empty space, and is very useful as well IMO.
#16 |
Old member
I wasn't trying to say the vacume gauge was worthless but I don't know of one person who honestly drives by that gauge. I have one in my new dash and in my 08 Tahoe and my wifes 2011 Trevearse and I never even look at them muchless try to drive by them.
Now as for the clock I use it everyday. The only reason I didn't go back with it is my radio has the clock in it so I didn't need two of them. Here is the new dash with speed hut gauges installed. Yes the vacume gauge is functional. It's in the same location as the orignal vacume would be. I should have put a trans temperature gauge in that spot. It would be more usefull that's for sure. ![]() ![]() ![]()
#17 |
Andy, I think the old dash would look great in my truck instead of on your shelf! I even plan on painting my truck orange. You interested in selling it?
What is the toggle switch for, down below the ignition key area?
#18 | |
Old member
![]() Quote:
#19 |
They did have air pressure dashes for the air brakes too. In a way the vacuum gauge can be useful to get a truck tuned to have maximum vacuum. However a vacuum gauge tool would do the job a little better. Stock vacuum gauge can determine if your engine is not running with full vacuum, but I would use a vacuum gauge tool to determine its proper vacuum.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#20 | |
#21 | |
