Old 05-04-2013, 06:04 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
hush mat?
Will 50sq ft do the footwell floor and rear wall. In a regular cab.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 05-04-2013, 07:08 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: hush mat?
Yes, if you don't waste any
I used paper to make templates for the curvy parts of the floor so it would pay flat. Worked very well.
bigblock73 is offline   Reply With Quote
Old 05-04-2013, 07:35 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: hush mat?
You start on the cowl or the rear of the cab?
Old 05-04-2013, 09:42 PM   #4
85supersierra
85supersierra's Avatar
Re: hush mat?
i started on the back of the cab and worked my way foward i bought my kit from mrhino on this site his product was great and much cheaper than the name brand stuff
Name:  truck floor.jpg
85supersierra is offline   Reply With Quote
Old 05-08-2013, 11:57 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: hush mat?
How many square ft did you use?
Old 05-09-2013, 12:06 AM   #6
dieseldawg142
dieseldawg142's Avatar
Re: hush mat?
50sqf should do you. i bought 100sqf for my crew, from firewall to rear wall plus both sides in the doors, up in the pillars, none on the roof. had 4 or 5 sqf left over.
dieseldawg142 is offline   Reply With Quote
Old 05-09-2013, 01:11 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: hush mat?
Cool something to do Saturday
Old 05-09-2013, 07:07 AM   #8
mopar346
Re: hush mat?
You might look at peal and seal from Lowe's same stuff basically and cheaper. This is the only link I found quickly but it comes in much wider rolls, 3 ft I think.
http://www.lowes.com/pd_154017-81326...1018733&rpp=32
mopar346 is offline   Reply With Quote
Old 05-09-2013, 09:30 AM   #9
andrewmp6
Re: hush mat?
Wear thick gloves the edges are sharp on some brands.And a good floor roller to smooth it out helps a lot.
andrewmp6 is offline   Reply With Quote
Old 05-09-2013, 10:41 AM   #10
Claytona08
Claytona08's Avatar
Re: hush mat?
Does this provide sound proofing equivalent to the hush mat?
Claytona08 is offline   Reply With Quote
Old 05-09-2013, 09:15 PM   #11
85supersierra
Re: hush mat?
I used a 58sqft kit from Mrhino. I did the entire back wall floor both doors and a few strips on the roof.
Old 05-10-2013, 12:43 AM   #12
dieseldawg142
Re: hush mat?
peel-n-seal, hush mat, fatmat, etc. dont really soundproof your truck, there more like dampners. they kill rattles & vibrations in your sheet metal. if you want real noise reduction, lay in some lead or mass loaded vinyl or something similar. peel-n-seal will kill rattles in your sheetmetal, but it's more asphalt based instead of butyl, & usually your truck will stink for a few days. it should also not be used on overhead surfaces, in really hot or really cold weather, it can fall off. i recently put fatmat & mlv with a foam decoupler in between in my crew, difference is like nite & day
Old 05-10-2013, 06:10 AM   #13
S10Fan
Old Heap Driver
Re: hush mat?
I have Peel & Seal in both my trucks, no "smell" issues at all, ever. P&S is NOT as good as the name brand stuff, and yes, it will fall off the roof in hot weather.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-10-2013, 09:13 AM   #14
mopar346
Re: hush mat?
No smell experienced, course it is usually laid down well before a car is finished and is let open in an open shop, so we may not notice it. As far as releasing from the roof, I have seen that in the Florida heat, one of the cures is to overlay it so it sticks to itself and use the supports in the roof structure to trap it in place, this would not work in a truck with no exposed support beams. Is make a vehicle CONSIDERABLY quieter and cooler in my experience.
Old 05-10-2013, 12:42 PM   #15
maxxxy
maxxxy's Avatar
Re: hush mat?
Peel n seal is better than nothing at all and is comparable to a few of the name brand dampeners. That being said it is not made for sound deadening. I found a link somewhere where they legitimately tested its sound deadening qualities compared to a real sound deadener.
Results were with 100% surface coverage with peel n seal, equivalent to 25% coverage of real sound deadener.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 05-11-2013, 02:30 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: hush mat?
Went down easy.Had a bit left over. Should've listened about wearing gloves.
No blood but ouch.
Old 05-11-2013, 08:50 PM   #17
mopar346
Re: hush mat?
Looks great, good job!
Good conversation by all.
Old 05-11-2013, 11:24 PM   #18
1slo_camaro
Re: hush mat?
how do yall know where all your mounting holes are, how about fitment for the door sills and all? im hoping once i get my jeep back on the road to take my truck down and re-do the interior and something to put on the floor after new floor pans and all is definately in the works.
1slo_camaro is offline   Reply With Quote
Old 05-11-2013, 11:55 PM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: hush mat?
I hand tightened bolts for seat and seat belts. And trimmed around. The sill trim has been patched so new holes are will be needed
