Old 05-04-2013, 08:27 PM   #1
Codez67Chevy
Codez67Chevy's Avatar
Electric fans?
I'm sure some of you are running electric fans. I would like to put one in mine for the old I6. I'm getting a new/used radiator cuz I'm cheap. I can get one with a fan already on it or buy one that could fit the whole radiator. So how did you guys do it? Cuz I'm also wondering how it would work with the temp sensor or just turn it on manually?
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 05-04-2013, 08:46 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Electric fans?
You could buy a kit from me.. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-04-2013, 09:07 PM   #3
Gene
Gene's Avatar
Re: Electric fans?
I used one from a Jeep grand Cherokee and it fit the stock shroud for 57 shipped on ebay. Works great.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-04-2013, 10:23 PM   #4
Codez67Chevy
Re: Electric fans?
So then whatcha got Wes?
Members I've met...
Mister-B
Old 05-04-2013, 10:44 PM   #5
Lattimer
Lattimer's Avatar
Re: Electric fans?
I bought a dual fan kit from jegs and got their thermostat kit.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-04-2013, 11:18 PM   #6
jdm0068
Re: Electric fans?
I got a dual speed Dual fan out of a Lincoln Continental, at the junkyard $50 then you just have to build a controller and relays for it. and build a custom frame to mount it to the radiator. Total less than $200 in parts, and a couple of hours labor
jdm0068 is offline   Reply With Quote
Old 05-05-2013, 01:18 AM   #7
Classic Heartbeat
Re: Electric fans?
http://www.classicheartbeat.com/cata...assemblies.htm
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-05-2013, 02:25 AM   #8
Codez67Chevy
Re: Electric fans?
Ummmm I would love to buy from you but I can't afford that yet.
Members I've met...
Mister-B
Old 05-05-2013, 10:19 AM   #9
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Re: Electric fans?
http://www.classicperform.com/tech_a.../Fantastic.htm
I used this kit. The article is the install procedures and I tried to find the actual kit on CPP. I can't recall which one it was, but it fits perfect for around $300.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 05-05-2013, 10:22 AM   #10
Leftlane
Re: Electric fans?
Wes,
In that wiring diagram I don't see where the thermostat recieves a signal to trigger operation. Is there a sender of some sort not mentioned?
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 05-05-2013, 10:30 AM   #11
westbrookw
westbrookw's Avatar
Re: Electric fans?
Yeah, the kit from CPP now comes with a 205 degree block unit. I had to research it when I did mine. Mine came out of a, I believe, '85 Camaro. It also had one fan running constantly and the other kicked in at 205 degrees, but I wired them in series so they would both kick on at 205 degrees. I didnt see the purpose of burning out one fan and using the energy. It works good.
72 SWB/Step
Old 05-05-2013, 11:03 AM   #12
bugmasta
bugmasta's Avatar
Re: Electric fans?
I run dual 14" fans with temp sensor. Drove in a parade Friday in the upper 80s with my a/c on the whole time and temp gauge never got above half way.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 05-05-2013, 11:39 AM   #13
Rufton
Re: Electric fans?
FWIW: I've had 2 electrical fan system failures and 0 mechanical fan failures.
Rufton is offline   Reply With Quote
Old 05-05-2013, 12:34 PM   #14
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Electric fans?
If its overheating electric fans won't really help. A clutch fan would do the same thing as an electric but will be a lot more reliable. A shroud would work wonders too.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 05-06-2013, 12:18 AM   #15
montefreak
montefreak's Avatar
Re: Electric fans?
I just installed a 406 sbc....four core radiator....got a double electric fan from a yard..(dont know what from but it does say FORD on it)....measured my radiator...found one that came close....built some brackets...wired it through a relay to a toggle switch in the cab....thats just what i did....hope it helps my friend....
montefreak is offline   Reply With Quote
Old 05-06-2013, 04:06 AM   #16
Andy4639
Old member
Andy4639's Avatar
Cool Re: Electric fans?
I have the clutch fan with shroud in my 71. I also picked up a 18" electric out of a mini van. Dual speed. I have it hooked to the A/C switch behind the controller so when I have the AC on it ingages the relay to the fan. No added switches and no need for a thermastast.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-06-2013, 08:31 AM   #17
RexDodge
Re: Electric fans?
RexDodge is offline   Reply With Quote
