05-04-2013, 08:39 PM | #1 |
882 heads?
Are these 882 heads with big chambers and hardened seats?
Got to hear the engine run but the PO "didn't know anything about it". Thank you in advance for all input.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
05-04-2013, 09:01 PM | #2 |
Re: 882 heads?
Only for sure way to tell is pull the valve cover and look at the casting #.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
05-04-2013, 11:05 PM | #3 |
Re: 882 heads?
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). Last edited by airdale94; 05-04-2013 at 11:06 PM. Reason: add |
