Old 05-04-2013, 09:05 PM   #1
eray92
eray92's Avatar
What is this actually called???
I call it a steering bar, I need a new one and need to know what its really called and if they sell them?
eray92 is offline   Reply With Quote
Old 05-04-2013, 09:51 PM   #2
LONGHAIR
Re: What is this actually called???
That is the "tie-rod". You should be able to get that at nearly any auto parts store.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-04-2013, 09:55 PM   #3
eray92
eray92's Avatar
Thats the part. But, both my tie rods are screwed on to it, its an 86. My 78 has the passenger side made into the bar.
Old 05-04-2013, 10:05 PM   #4
donut
donut's Avatar
Then how about an adjusting tube? Some of the 4x4's, the left tie-rod is really long.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-04-2013, 10:13 PM   #5
mopar346
I have always heard it called the steering link and the drag link is the one that attaches to the pitman arm.
mopar346 is offline   Reply With Quote
Old 05-04-2013, 10:14 PM   #6
eray92
eray92's Avatar
The left tie rod is longer than the right and the left one has a hole in it for the stock stabilizer. It has a nut attached to each side and the tie rods screw into it. Went to get an alignment today and its bent.
Old 05-04-2013, 10:15 PM   #7
eray92
eray92's Avatar
Thank you everyone for the replys. I'll see if I can find one
Old 05-04-2013, 10:16 PM   #8
y5mgisi
Second Chance Program
y5mgisi's Avatar
Only place i Know of to get one is LMC truck. But im sure they are everywhere.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-04-2013, 10:18 PM   #9
eray92
eray92's Avatar
Thank you!!!! And they are cheap ha
Old 05-04-2013, 10:25 PM   #10
LONGHAIR
The entire thing from one knuckle to the other is the "tie-rod". The style just depends upon the year of the truck. The earlier models had; one long rod, one short "end", and the adjuster sleeve with clamps.
The later ones had 2 short ends and the center section was the adjusting sleeve. IIRC, they had jamb nuts on the ends? This made it so that the main rod itself was not a wear-out item, it would only be replaced in the event of damage.
Old 05-04-2013, 10:29 PM   #11
eray92
eray92's Avatar
lmc says the one I need is for a truck with 4.10 rear gears and w/o 13" rear brakes. my truck came with 3.42 gears, so someone has changed it I guess
Old 05-04-2013, 10:31 PM   #12
y5mgisi
y5mgisi's Avatar
No silly, Its calling out 9 as a "D". That says, without 13" brakes and 4.10. As in without either of those items. Notice that "C" is with 13" brakes and 4.10's. Your tierods/adjuster tube is original.
Old 05-04-2013, 10:33 PM   #13
eray92
eray92's Avatar
for some reason when I was reading that, I saw " w/o 13" brakes and with 4.10 gears" ha sorry about that and thank you
Old 05-04-2013, 10:44 PM   #14
eray92
eray92's Avatar
ok so the part number is 34-1180 it $50.70 shipped to my door from LMC. thank you everyone
Old 05-04-2013, 11:04 PM   #15
y5mgisi
y5mgisi's Avatar
Your welcome! keep in mind thats only LMC's part number.
Old 05-04-2013, 11:06 PM   #16
eray92
eray92's Avatar
I looked on advance autos site and o'reillys site but they don't carry them. I assume LMC is the only carrier
Old 05-05-2013, 08:52 AM   #17
LONGHAIR
Sources may be a bit more limited, like I said, because that is not a wear-out item. You only need to replace it if it gets damaged (bent), normally you just need the ends.
Old 05-05-2013, 01:37 PM   #18
75chev4x4
75chev4x4's Avatar
Any auto parts place should have these, I know off road design has some nice beefy ones. I wouldnt buy the lmc ones, I did and they are overpriced junk imo.
75chev4x4 is offline   Reply With Quote
Old 05-05-2013, 03:28 PM   #19
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I just replaced items 4-6,10-12 & 17-19 on my '90 3/4ton suburban. While using the pickle fork to seperate the right side tie rod end from the knuckle the socket fell off of shoulder pin. AND I HAD JUST DRIVEN IT BACK FROM WASILLA, AK. 65 MILES AWAY!!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
