Steering column grease
I'm in the process of rebuilding a non-tilt steering column for my '71, and I need to know what parts need greased inside of the column, and what type of grease is suitable for this. I know that obviously parts that move need greased, but everything was pretty much dry when I disassembled it. Any input is greatly appreciated. Thanks
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: Steering column grease
Anyone?
So am I not supposed to lube any part of the shifter tube?
I did this a couple weeks ago. I did the top and bottom bearings of my non-tilt column. The grease in mine was completely dried up from sitting for way to many years. A quick trip through the solvent tank and they cleaned right up. I repacked them with normal wheel bearing grease. Not sure if that was the right kind of grease, but it is certainly better than it was before.
Ive read on here to douse the column in white lithium grease spray.
Active Member
![]() Join Date: Jul 2007
I cleaned the shaft out of all the old, dried up grease and I also used a thin layer of wheel bearing grease. Here in Texas we have some really hot summer (100 plus) days for weeks on end and I didn't want grease to drip down the shaft.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
