05-05-2013, 12:19 AM | #1 |
Vintage 4x4s
Is this a 292?
Bought a K20, has a 292 on the SPID and the PO says this is it. This is a pic of the engine in the shed, Can you confirm that its a 292 or at least looks right for a early 70's I6 chevy? Pic was taken at night. Also, is the bellhousing the same for this as a SBC?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
05-05-2013, 12:56 AM | #2 |
Re: Is this a 292?
Looks like a picture out of a horror movie, poor motor. It does look like a 292 to me. Being that I have one.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
05-05-2013, 01:49 AM | #3 |
Re: Is this a 292?
If the motor mounts are offset from each other, it's a 292. If they are straight across from each other, it's a 250/230. And the lifter covers are 6" tall on the 292 and 4" tall on the 250/230s And yes, the bell housing is the same.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
05-05-2013, 09:33 AM | #4 |
Watch out for your cornhole !
Re: Is this a 292?
Yes it's a 292.
You can tell by the large bypass hose on the front of the engine which is 292 specific. 230/250 engines do not have that bypass. Posted via Mobile Device |
05-05-2013, 01:20 PM | #5 |
Vintage 4x4s
Re: Is this a 292?
Sweet. thanks gentlemen.
Next question, he said its tired so I'm wondering how easy/expensive these are to rebuild? They typically need many parts to rebuild or just bearings, rings, and valve/head work? Know of any good rebuilders for these? Anything tricky that a typical SBC rebuilder would have trouble with? I would like to do myself but just don't have time.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 05-05-2013 at 01:28 PM. Reason: spelling |
05-05-2013, 04:38 PM | #6 | |
Re: Is this a 292?
Good luck with it and let us know what you find. If it comes to getting it bored, make sure your machinist has a torque plate to bolt to the top of the block.
05-14-2013, 12:03 AM | #7 |
Vintage 4x4s
Re: Is this a 292?
Any thoughts on how easy/expensive these are to rebuild? They typically need many parts to rebuild or just bearings, rings, and valve/head work? Know of any good rebuilders for these? Anything tricky that a typical SBC rebuilder would have trouble with? I would like to do myself but just don't have time.
