Old 05-05-2013, 04:19 PM   #1
olllie
olllie's Avatar
Question Factory Seat Belt, operation question..
May be a stupid question but,
I have noticed that both of my 3 point factory belts do not lockup. Seems like on most modern cars if you give the belt a quick tug the belt return will lock..
meaning in an accident the belt will stop your body from becoming part of the dash..
Do I need new belts?? or is this normal in all these trucks.
1987 GMC Wrangler 350/700r
olllie is offline   Reply With Quote
Old 05-05-2013, 05:04 PM   #2
tucsonjwt
Re: Factory Seat Belt, operation question..
On my 83, the driver's side seat belt does not lock, the passenger side does. All other vehicles I have owned lock when yanked (inertia feature.) So, I say they should lock when yanked and both you and I have improperly functioning seat belts. The lap belt portion does stay in place.
tucsonjwt is offline   Reply With Quote
Old 05-05-2013, 05:25 PM   #3
olllie
olllie's Avatar
Yes I agree with you, looks like both my belts are junk. my lap and shoulder belts do not lock at all... even with a real hard pull. that sucks because belts are not cheap and finding one in a wrecker in my area is not going to happen.
Any idea if newer pickup belts will fit?
Old 05-07-2013, 06:41 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
is this with the door open or closed?
my drivers locks with the door closed,not open
there is a pin in the door jamb,open, it releases the belt
make sure it's not jammed or fulla paint and stuck
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-07-2013, 08:08 AM   #5
mrolds88
Double check those belts. I'm pretty sure there's an inertia mechanism in there. A little round weight underneath that activates the locking pawl. Good test would be to find a desolate piece of blacktop and get the truck to about 40 and apply the brakes hard (not lockup) to check the belt lockup. If they don't lock then, replace.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-07-2013, 11:02 PM   #6
mtnsackett
mtnsackett's Avatar
if you want to keep your original belts check out the link, they can rebuild them to like new and you will never know that they were broken.
http://www.ssnake-oyl.com/mm5/mercha...tegory_Code=RS
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world!
mtnsackett is offline   Reply With Quote
Old 05-08-2013, 12:02 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Mine if I go over a bump with enough vigor they look up. I believe this is the inertia lock activating correct?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
