RAT1968 '68 Cab/'71 Parts
Boring HEI Dilemma?
Ever since I brought the truck home from the big part of the build, I've had surprises in the area of "no-start". Never can tell when it's going to happen.
Once I got the timing dialed in, the drivability has been perfect. Starts at the touch of the key.....Except when she doesn't. I can go two weeks and it just starts and runs and fun is had by all. Until, like this morning, out I went and crank, crank, crank...no fire. Never happens when it's been running the same day. I've been through all sorts of fixes. To the point that I now know it's spark related. If anyone has read this far, then maybe you like puzzles enough to give a guy a tip or two. Even though I'm afraid to lose you, here's what I've done over the time trying to stop the intermittent starting problems: I'll leave out the fuel side of it, because I've been from tank to manifold, including adding an electric fuel pump. It's electrical. Here's how I know: I connected the timing light and, with the hood open, I shoved the nose (of the light) between the cowl and the hood and made a shadow box so I could see (from the drivers perch) if the light flashes while I'm cranking...trying to start up. It doesn't. The distributor is an Accel HEI that came with the truck. My bias leans in favor of it being screwed up...But that's why I need to ask you all.... During all of this, earlier I replaced the coil, being careful to get all the parts in the right place. The truck ran fine after that and didn't display starting problems. But that was a couple of months ago. Today, I checked for 12v at the connector. It had it. Even so, today I again tried a direct line to the battery in the engine compartment for a test. Used a decent gauge wire. No change. Previously, during my trying to figure out the starting issue, I had moved the wire into the cab..... I went (same decent gauge...I think 10g) directly to the fuse block for the juice. She ran and started fine until today. Today, I pulled the new(ish) coil off of the top of the dizzy to check the ground, "Tach" and "Batt" blades, the rubber doughnut and the spring and "plunger". There was still a small amount of the dielectric (sp?) grease on the rubber "doughnut", and everything *looked* okay. Buttoned it back up and, for the test, went back to a direct wire from the Batt on the dizzy to the + side of the battery, re-connected the timing light and put it back in its viewfinder between the hood and cowl. "Crank, crank, crank, crank, crank." I have to say that all this time, in between tests and no-starts, I'm checking for over 12v at the battery and the batt connector on the distributor. And, just because I'm paranoid, I'm looking down the gut of the carb to make sure the "squirt factor" is there. So, I'd love to have any comments. Particularly, I'm scratching my head over the fact that it starts (fires right up) enough of the time to make me thing that she's now reliable. Until, like this morning, she didn't....And WON'T.....until I do SOMETHING. In fact, I was so p*ssed that I couldn't figure it out (when I thought I HAD long before this), that I just took the coil back off, put the air cleaner back on, and hooked up the float-charger to the new, disconnected BOSCH battery. I'd LOVE a hug!!!
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 05-05-2013 at 05:52 PM. |
Always on the hunt...
![]() Join Date: Sep 2006
Re: Boring HEI Dilemma?
I would look at the control module for an intermittent spark issue, over the years I have had a few bad ones produce the same results you are talking about. Mel
Hey, Mel. Thanks.
Don't have a control module. Maybe that's the problem? One wire set-up on the harness for the alt. The only wires in the HEI set up are the Tach to the + of the tach, BATT to 12v in the harness, the coil on the top of the HEI, and the plug wires to the plugs. There ARE three wires that run from the lower body of the dizzy to the general area that the BATT and TACH connectors attach, though.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'd bet the module is your culprit.
The module is the little flat electronic box thats under the distributor cap screwed to the distributor housing. It's held down by a little screw on each end. Posted via Mobile Device |
Cool. That's my next check.
Thanks, Guys. I bet you are correct.....I didn't even know it was there. Hahahaha!!!!
Ignition modules are one of the places where quality is paramount. No Chinese cheapies here. Step up to an AC Delco module or similar quality.
#7 | |
![]() Last edited by Classic Bowties; 05-05-2013 at 06:49 PM. Reason: added info |
Forgot pic...
You guys just made my night a lot better.....In fact, you made my next three weeks waaay better.
The Boss (42 yrs so far) and I are taking off for Europe tomorrow morning. I would'a spent too much time thinking about this while strolling the streets of Paris. (I'm a cheap date...that's what we do on a trip). Now, all I'll have to do is find the correct module (agreed on the quality thang TxFF), and try that out when we get home. Feelin' good about that as a fix. You guys are at the very top of my "Good Guy List" today. Thanks again. ![]()
Rock auto has the AC Delco module. It could be waiting in your mailbox when you return from Paris.
If you want, here is my 5% discount code they emailed me recently. Help yourself. Code....1417751610932017 Posted via Mobile Device |
laying low
![]() Join Date: Mar 2001
Man I know you hate to see your stuff on a rollback. I sure do. I've had my share of dist issues just like yours. It's good insurance to carry a spare module in the glove box. One day you will need it. Have a nice trip.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#12 | |
Thanks a bunch for the code.
