Old 05-05-2013, 05:22 PM   #1
missionstreettattoo
missionstreettattoo's Avatar
headlight issue
my passenger side headlight does not have a high beam for brights. it doesnt work. i changed the headlamp and it still doesn't. is there a fuse for the brights on left or right? or is this something else?
missionstreettattoo is offline   Reply With Quote
Old 05-05-2013, 05:35 PM   #2
longbed67
longbed67's Avatar
Re: headlight issue
Does the drivers side work? if so check your harness to make there is a good connection on all three pins and the ground. Also follow the connection back to the high/low switch to make sure it isnt getting grounded out.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 05-05-2013, 05:36 PM   #3
missionstreettattoo
Re: headlight issue
thanks!
