spectra a369 radiator?
My current radiator is leaking.I purchased a new one from autozone.It appears to be a very nice radiator its all metal.My only problem is its a 4row.My old one is a 3 row.The trans cooler lines are a little farther apart as well.Is all i need is another set of upper brackets?What about the coolerlines?I realy don't want to modify them.Has any body else used this radiator?Or am I better off returning it and looking at other options?
Active Member
![]() Join Date: Oct 2002
Re: spectra a369 radiator?
I just had to do this also, you should be able to move the cooler lines into place
But you will have to replace the lower 3 row radiator brackets also, I used a chisel to cut the rivet. |
![]() Join Date: Feb 2011
You might also need to notch out the bottom of the raditator support, as the four core brackets are a little longer. The trans lines you should be able to bend and move some.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
Thanks guys.I guess I need to check out lmc or another company for the brackets.I thought about modifying mine but I would still need the rubber.
