Old 05-05-2013, 07:49 PM   #1
wicky
wicky's Avatar
Wiring harness/fuel pump
Hey guys im trying to finish up 5.3 swap in my 69. Its a 5.3 out of an 04 Avalanche. I sent the harness off to be stripped and cleaned up. I have 2 relays. One labeled main and one for my fuel pump. My question is my fuel pump relay has a green and white wire that comes out of the ecm plugged in where u would put a 12v key switch wire. And the main relay has a key switch plugged into the same spot. My problem is the fuel pump has no switch power to trigger the relay. Is the green/white wire correct and i just have something hooked up wrong somewhere else? Or are my relays possibly wired up wrong by mistake.
wicky is offline   Reply With Quote
