Disc brake rear end and better gears?
I have a cummins in my truck. Getrag 5 speed. It tops out at 85-90. looking into disk brakes for the rear as well. About to be hauling a BIG enclosed trailer.Was hoping there was an axle I could get that has both? Or what parts do I need? What options do I have here? Or do I have any?
Re: Disc brake rear end and better gears?
What rear end do you have now? What rear gears? Tire height? More top speed & more pulling power are two different things.
#3 | |
A drum can actually stop better than a disk setup untill they get real hot which they fade like most brakes normally do. They don't drag as much and the force they apply is multiplied exponentially since they self energize. This can be both good and bad. Bad when you race and your rears lock up and good for towing with alot of weight over the rear axle. They also always employ an e brake. Some disk setups do not employ an e brake but the disks are able to cool faster and depending on how they are equipped can outstop drums easily and hold stooping force longer. The stopping power is mor linear which means you can bias more rear stopping power and modulate your brakes better without fear of locking up the rear. Just some thoughts to look at. A place to look for kits would be blackbirdscustoms.com based out of Spokane wa. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I put an 03 disk brake 14b in my crewcab, doesn't stop any better than the drums I took out. it is easier to work on the brakes though. my truck will go in excess of 105 with 3.73 and 35's.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
good to know ahead of time! Better than wasting money for sure. Not sure of the gears it has now. Tires are 235 85 16's.
And rear disc get pricey when its time to replace them.I would leave it drums and regear your rear end you have now.
At the body shop.
Chevrolet was disc and now back to drums.
" That didnt make it any newer " " Dont antique the equipment " |
thanks for the help guys. At least I know before I just go ahead and do it. I had heard mixed comments about it. Thought I would ask and get a few more opinions.
Which rear end do you have in it now?
Only for a few years while they hammered out some revisions, they're disc again.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#11 | |
At the body shop.
![]() ![]() ![]() 2500's have disc. 1500's are drums. Posted via Mobile Device Posted via Mobile Device
#12 | |
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 05-08-2013 at 11:02 AM. |
#13 |
Because disc brakes are less susceptible to brake fade, heat-related problems and the like, I imagine they are overall more responsive than drums. That's likely why new vehicles are coming out with 4-wheel disc brakes. I don't think it's necessarily to improve braking, because the vast majority of the braking force occurs at the front brakes. I figure it's due to the disc brakes being more responsive, they are going to be much more effective with computerized traction-control.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#14 |
At the body shop.
Lol no problem. Hope the parking brake works better.
#15 |
I have disc brakes on my R3500. I pull heavy loads, up to 10k pounds, and the truck stops better and is more predictable than having the heat build up my drums had. I have $365 into the total conversion. If I went with an ebrake, it would have been about $100 more. I still might do that. I am happy with the discs. Now I don't have to pull the hubs to change brake pads either. But to each there own. Do whats best for your taste.
Posted via Mobile Device |
#16 | ||
Thanks c Quote:
That is with the old stock rear. My current Ford 9 inch/rear disc combo rear brake rotor is $47. Pads are $18 So.......drums are more "pricey" And when you add the hardware kits for drums it's even more pricey. Oh, I also have a working emergency/parking brake. As for the precentage of braking front vs rear, I think it depends alot on how you drive your truck. If you have a car type stick shift (like a T56 for example) and set your truck up to handle in corners then you may run more (even alot more) rear brake than you would with an automatic. Non power is another case where you may be able to use more rear brake bias. How could you even tell how much rear bias you have with the factory power brakes? No road feel at all My rear wheels get an awful lot of brake dust build up in a very short time. My rear caliper pistions are the same size as my fronts. Rotors a little smaller (11.5" rear vs 12"? front) All prices are current from autozone web site as of air time... ![]()
![]() Last edited by wraprail; 05-10-2013 at 12:17 PM. |
#17 |
To answer the OP's original question (I'm sorry I didn't cover it before.), you have several options... You could look for an axle out of a newer truck and move the spring perches, swap it in. You would then have a more modern axle with a well engineered braking system. You can also use any number of kits available online to convert your rear axle to disc brakes. There are a lot of companies that make the brackets and sell kits.
First here is a good DIY, how & why write-up: http://www.fourwheeler.com/techartic...ke_conversion/ One of my favorite, because they offer caliper options and rotor options is: http://www.tsmmfg.com/reardiscbrakes.html Also: http://www.blackbirdscustomtrucks.com/index7.html Brackets available everywhere it seems like now: http://www.offroaddesign.com/catalog/14FFdisckit.htm http://www.ruffstuffspecialties.com/catalog/BoltOn.html http://www.greatlakeoffroad.com/GLO-...rake-Brackets/ http://www.tmrcustoms.com/store/inde...fbc21e2abf6df5
#18 |
The factory rear disc on my brothers 01 f150 was 66 a rear rotor and pads was 20 something.Which 9 inch rear brakes do you have tho?
#19 | |
Mine is from a 1979 Lincoln Mark V ![]() Posted via Mobile Device
