05-05-2013, 11:01 PM | #1 |
Power steering help
Any one have a pic of the original power steering pump bracket on a v8 truck ?
05-05-2013, 11:11 PM | #2 |
60-66 Nut
Re: Power steering help
Do you have a small block, and does it have the short water pump as came in these trucks originally?
05-05-2013, 11:17 PM | #3 |
It a small block 350 but I'm dressing it up like a 283 And I'm putting a short water pump in it just like the original. It also has factory A/C if that makes difference
Posted via Mobile Device |
05-09-2013, 01:45 AM | #4 |
id like to see. i got a 67 as a bit of a basket case and im going to make it live. id hate to fab up something when i could make what i have work.
IMG_5282 by trevor ward tattoos, on Flickr |
05-09-2013, 02:08 AM | #5 |
I should be able to get 1 later today.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
05-09-2013, 02:13 AM | #6 |
tward-Not sure but I think that bracket is for a inline 6
05-09-2013, 08:07 AM | #7 |
Watch out for your cornhole !
He has a long water pump small block power steering setup in that picture. Same one that was on 73-87 trucks.
05-09-2013, 11:56 PM | #8 |
60-66 Nut
As already said, that PS pump bracket assembly is for a long water pump, which is what is on the engine currently. If you switch to a short water pump, you will need all the correct pulley's and brackets for a small block with a short water pump. The '68 and earlier cars and '72 and earlier trucks had short water pumps.
05-10-2013, 02:09 AM | #9 |
Ok cool I have the long water pump setup but I'm switching to a short setup so my factory A/c system will work but I can't find a short water pump p/s pump bracket for a truck. so I don't evin know what I'm looking for. Was it the same as on the cars and dose anyone have any pictures of one?
05-11-2013, 12:36 AM | #10 |
60-66 Nut
The '63-'66 trucks used the same power steering pump brackets as the '63-'68 cars. There are a couple slight variations, bu they are basically the same.
There are 2 or 3 variations of the power steering pump brackets for the '67-'72 trucks. But they are basically the same. Here is one of the many aftermarket short water pump power steering pump brackets.
05-11-2013, 12:48 AM | #11 |
That's just what I wanted to know/ see Thank you. Now I know what to look for at the junkyards/ebay
