05-05-2013, 11:38 PM | #1 |
Square bore?
New to engines for the most part. Getting an edelbrock 1407 carb. Says square bore well what does this mean and what do I need to do. Thanks
72 GMC super custom. |
05-05-2013, 11:43 PM | #2 |
Re: Square bore?
Means all of the holes on the bottom of the carb are the same same size. Some have two larger and two smaller holes. What are you converting from? What intake manifold do you have?
05-05-2013, 11:45 PM | #3 |
Re: Square bore?
Really not for sure. Stock I believe at this point
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
05-05-2013, 11:55 PM | #4 |
Re: Square bore?
May need others to chime in here, Quarajet to four barrel conversion. Looks like you may need an adapter if you are going to keep the stock manifold.
Part number 2696 from Edelbrock's webiste Four-hole, Square-bore to Spread-bore Adapter (.850") Mounts Edelbrock square-bore carbs to stock Quadrajet & Thermo-Quad manifolds. 2696 |
05-06-2013, 12:02 AM | #5 |
Re: Square bore?
Ok. Thank you
05-06-2013, 12:38 AM | #6 |
Re: Square bore?
A factory intake should be a spread bore. Easiest way to explain is the spread bore has large "butterflies" on the secondaries errr its bigger at the rear where a square bore is symmetrical or equally square. Harder to explain than I thought. Perhaps a pic will do much better.
Pic 1 square bore Pic 2 spread bore There is an adapter but it only goes one way and I forget which way it adapts at the moment.. getting old sucks
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
05-06-2013, 09:38 AM | #7 |
Re: Square bore?
1972 C10 CST LWB |
05-06-2013, 09:39 AM | #8 |
Re: Square bore?
Thanks!
05-06-2013, 12:20 PM | #9 |
Proprietor of Dale's Corner
Re: Square bore?
most adapters do go either way, from square to spread and vice versa. check Summit for adaptors
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
