Old 05-06-2013, 06:49 AM   #1
dey59
bent push rod
my 72 sbc has low compression even after wet test. dry everything is between 160 an 170, no. 6 is 135. wet everything came up about 5 bls. or so, no. 6 about 138. I pulled the intake and found a bent pushrod on no.6 intake would this account for the low compression. it seems the valve would be closed more an wouldn't cause low compression do I have a burned or bent valve. thanks
dey59 is offline   Reply With Quote
Old 05-06-2013, 07:23 AM   #2
SS Tim
SS Tim's Avatar
Re: bent push rod
Sounds like a valve problem. Did you do a cylinder leakdown test?
SS Tim is offline   Reply With Quote
Old 05-06-2013, 09:16 AM   #3
Lee H
Lee H's Avatar
Re: bent push rod
Yup, it's time for a leak down test.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-06-2013, 01:58 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Re: bent push rod
I agree, it is time for a leak down.
The intake valve has to open all the way to make good compression. My question would be why did the intake push rod bend? Did the valve stick in the closed position? It only takes one revolution to cause damage. You need to figure out the cause or it might happen again. Push rods typically don't just bend.
TBONE1964 is offline   Reply With Quote
Old 05-06-2013, 02:34 PM   #5
1badcholo
Re: bent push rod
Yes, the bent push rod would prevent either a full intake of air, or a complete exhaust of air in the cylinder preventing a full intake charge. Replace the push rod they are available for cheap ~4.00 at your local parts store. That will likely fix the issue. Good luck.
1badcholo is offline   Reply With Quote
Old 05-06-2013, 08:59 PM   #6
luvbowties
luvbowties's Avatar
Exclamation Re: bent push rod
You may want to check for a stuck lifter OR a sticking valve: something caused the pr to bend. Need to find WHY first, imo!
Sam
luvbowties is offline   Reply With Quote
Old 05-06-2013, 09:53 PM   #7
dey59
Re: bent push rod
thanks guys, replaced the push rod on no. 6 it brought the compression up about 5 lbs. to 140. I went and bought a new compression gauge to make sure, other cylinders are 180 to 190 dry no. 6 is 140 I'm pretty sure i'm gonna pull the heads. thanks for the input guys. I don't have equip. for leak down test never done one before, i'm still open to idea's. how can I test for stuck valve lifter looks ok its going up an down doesn't look collapsed.
Old 05-07-2013, 12:17 AM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: bent push rod
Had our 235 do same thing rebuilt the head. Vavle stuck
John
1999 Toyota Tacoma 4x4
Old 05-07-2013, 02:12 AM   #9
romy505
Re: bent push rod
might want to check the valve guides,could have had a valve stick in the guide,had this happen on my 396
romy505 is offline   Reply With Quote
