Old 05-06-2013, 02:25 PM   #1
hoover
electric fan switch ?
have a 71 swb .with 05 6.0L and im using dual elect. fans
my problem is i dont know where i can mount the switch...can be possible water pump just before the thermostat.?
thanks..ronald
hoover is offline   Reply With Quote
Old 05-06-2013, 06:42 PM   #2
Crash_OK
Crash_OK's Avatar
Re: electric fan switch ?
thanks..ronald
I did not use a switch, I let the PCM control the fans. Is that a option for you?
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 05-07-2013, 06:28 PM   #3
hoover
how can i do that? do yuo know wich pin and color wire ? the pcm has to be reprogram...thanks ronald
Old 05-07-2013, 06:37 PM   #4
Crash_OK
Crash_OK's Avatar
I can look for my wiring stuff, but I think you should be able to find it on the LT1swap site. If your PCM is out of a 05 it should already be programmed I think.
Fan 1 is blue connector pin 42
Fan 2 is green connector pin 33
Mark
Crash's 69 4x4 SWB
Old 05-11-2013, 02:14 PM   #5
hoover
mark .the pin 42 in the blue connector goes to .
sending side of the relay?....thanks ronald
Old 05-11-2013, 07:21 PM   #6
Crash_OK
Crash_OK's Avatar
Ronald,
The PCM takes either of the Fan Control wires to ground to energize the fan speed requested by the logic in the PCM. Below is a drawing of how I wired my fans. When Fan1 control is low (ground) both fans turn at low speed. The three relays create a series circuit for the fans. When Fan2 control is low (ground) both fans turn at high speed. The three relays create a parallel circuit for the fans.
Hope this helps..
Mark
Crash's 69 4x4 SWB
Old 05-11-2013, 09:47 PM   #7
jorgensensc
jorgensensc's Avatar
So if I wanted to complicate things (great drawing by the way)How would I wire the trinary switch for the AC in so that when I turn on the AC it would automatically kick everything up to high. Also, I'm a bit confused I thought one fan ran, then the other fan kicked on when the computer said it needed it. Are most factory dual fan setups dual speed also? I'm running 2008 Escalade Electric fans. One last question, where did you put the diodes in your schematic? Or did you just use Relays with the diodes built in, like the factory relays?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-13-2013, 12:00 PM   #8
hoover
thankyou very much...mark
i will re wire today.thankyou again
ronald
Old 05-13-2013, 03:51 PM   #9
truckdude239
truckdude239's Avatar
just an fyi you might need to have the fans turned on in the tune
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-13-2013, 07:57 PM   #10
Crash_OK
Crash_OK's Avatar
Shawn
The ternary switch that I used works by taking the fan wire on the switch to ground as well, so I simply ran the wire off the switch to connection 86 on the top relay in my drawing. This puts the fans at half speed. I would have to do some thinking on have the ternary switch pull the fans up to full speed. I think you might be able to do it with a additional relay.. I am not much of an AC guy, so I am not sure if it needs to be at high speed. Do you know? If it is necessary I will work on it..
The relays have diode built in…
Mark
Crash's 69 4x4 SWB
