Old 05-06-2013, 06:03 PM   #1
weever82
weever82's Avatar
water pump acting up... short or long pump??
I got some problems with my water pump last night and went on summit to check around at pumps... seems there is a short pump and a long pump?
How do I check to see which one I have? Don't want to order the wrong one.
Thanks for the help! Its a 454 ci.
Also any recommendations on a good pump??
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 05-06-2013, 06:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: water pump acting up... short or long pump??
That's a long pump
Keith
Convert to disc brakes.
Old 05-06-2013, 06:09 PM   #3
lolife99
lolife99's Avatar
I really like Edelbrock's aluminum water pumps.
They helped me cure a "hot running truck" years ago,... and I will now use them, exclusively.
Keith
Old 05-06-2013, 06:11 PM   #4
lolife99
lolife99's Avatar
A short pump is on the right,...
Keith
Old 05-06-2013, 06:15 PM   #5
weever82
weever82's Avatar
Appreciate the help Keith! I have never swapped one out before... Pretty easy?
Weev-
Old 05-06-2013, 08:26 PM   #6
lolife99
lolife99's Avatar
Very easy,... and very messy.
No matter how hard you try,... you will have anti-freeze on the ground.
Take your time and just remove and replace.
And remember the trucks with a serpentine belt drive set-up, usually run a reverse rotation water pump.
I couldn't remember what you have for your accessory drive.
Keith
Old 05-06-2013, 09:10 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
When I change water pumps I usually replace the thermostat and check the hoses real good.
If you change the thermostat drill an 1/8" hole it, it will allow the thermostat to open easier because the pressure will be equal on both sides.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
