Old 05-06-2013, 08:08 PM   #1
earnhardtgm3
earnhardtgm3's Avatar
Harmonic Balancer
I need to put a harmonic balances on my 77 chev truck.The motor did not have one when I got it and had no timing cover.So I need to get a harmonic balancer and am going to be using this timing cover as I went to a hyd roller cam setup.
http://www.cloyes.com/HighPerformanc...S/Default.aspx
Do I need a 8 inch balancer?
Will also need timing pointer for timing cover as they are made in 6.75 or 8.00 in.
Looking at htis timing pointer.
http://www.tciauto.com/tc/chevy-smal...balancers.html
1977 Chevrolet Scottsdale:
1979 Camaro Z2/8
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is offline   Reply With Quote
Old 05-07-2013, 12:12 PM   #2
Krwright
Re: Harmonic Balancer
You can use either balancer just get the correct pointer for the balancer you use. They don't balance anything anyway they are a damper. Either size will work fine.
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
