Old 05-06-2013, 09:04 PM   #1
ReeseBobby
ReeseBobby's Avatar
2wd 14 bolt rear axle fit on 4wd?
Hi guys,
I'm trying to get my stuff together for my axle swap on my 1970 C20. I've got a line on a 14 bolt rear axle. It came from a 73' 3/4 ton, but the perches were adjusted and put onto a 72' 2WD 3/4 ton.
My questions are: Is there any difference in a 2WD rear vs a 4WD? And if the perches have been adjusted to fit on a 72' 2WD, will I need to do anything besides bolt it in on my 70' 4WD? I have a leaf spring truck and that's what it came from. Anything else I'm missing? Thanks!
ReeseBobby is offline   Reply With Quote
Old 05-06-2013, 09:07 PM   #2
b454rat
Re: 2wd 14 bolt rear axle fit on 4wd?
For the most part they are the same. I did one to a truck years ago, only thing I remember were the shock mounts were a little shorter, therefor the shocks would hit the axle tube. Not a big deal really, I just put a small dent on the shock tube. Other than that, I can't think of a difference.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 05-06-2013, 11:00 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
my axle came out of a 2wd truck. Bolted right up.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-08-2013, 06:22 AM   #4
So,a 67-72 C/20 rear will bolt directly into a same year K/20?
Old 05-08-2013, 06:00 PM   #5
b454rat
Didn't the 2 wheelers have coil springs??
Old 05-08-2013, 07:17 PM   #6
They had either coils or leafs. A Dana 60 from a '72 C/20 will not bolt up to a '72 K/20 frame to the best of my knowledge.
Old 05-08-2013, 07:45 PM   #7
b454rat
I've never owned a 67-72, but when I had my '62 4wd burb I was looking for axles for it, I looked at those styles and thought that the rear was 40.5" spring perch, which is the same as 73-up 1 tons.
Old 05-08-2013, 09:02 PM   #8
Mike C
Mike C's Avatar
67-72 2x4 trucks have a 42.5" spring center. The 4x4 has a 40.5". The 73-87 2 and 4 wheel trucks have 42.5" spring centers in half and 3/4 ton variants. K30 trucks have 40.5" spring centers. Shock mounts are different between all.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-09-2013, 09:01 AM   #9
Thanks Mike for the thorough info. I'm sure this helps the OP better than my "...to the best of my knowledge". I'm sure this helps us all. Gotta start writing this stuff down!
Old 05-09-2013, 08:33 PM   #10
ReeseBobby
ReeseBobby's Avatar
This is exactly what I was looking for. Thanks a lot!
Old 05-10-2013, 08:21 PM   #11
Mike C
Mike C's Avatar
I'm glad I have found a place where what most people consider "useless" information is actually useful!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-11-2013, 09:44 AM   #12
No,the info is very useful...no doubt! It's the person giving it I'm not so sure about. Huh? Oh damn!! Gotta go!!
Old 05-11-2013, 08:22 PM   #13
Mike C
Mike C's Avatar
LOL. We need a like button. I'd like that.
44 Willys MB
52 M38A1
64 Corvette Coupe
