Old 05-07-2013, 12:33 AM   #1
jorgensensc
jorgensensc's Avatar
Stock Air Intake?
Hey Guys,
I'm trying to keep things pretty simple on the l92 swap. I know there are cold air intakes made for these, but I kind of like how quite the factory intakes are. My problem is that I need to do the air box on the drivers side. I'm trying to use a factory surge tank and keep the battery tray in the stock location also, so the passenger side is a little crowded. Has anybody used a stock air box on the driver side? If so what vehicle was it from? I looked at the Camaro boxes, but I'm not sure they will fit around the alternator. Pics would be great!!! Thanks Guys!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-07-2013, 12:57 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Stock Air Intake?
what about something straight forward, if you have room above the radiator, you'll have airflow through the nostrils on the hood.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-07-2013, 01:06 AM   #3
jorgensensc
I looked at that idea. No nostrils on my hood, '72 Suburban. The way the core support is set up with the stock hood there is no room for air to go over the core support. Bummer!!
Old 05-07-2013, 06:35 AM   #4
Crash_OK
Crash_OK's Avatar
I attempted to do it. I could not get it all to fit, so I moved the battery.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 05-07-2013, 11:03 AM   #5
ls1nova71
ls1nova71's Avatar
I agree, easier to move the battery.
Any particular reason you're keeping the surge tank? A factory '72 raadiator is all you need to cool these engines. Surge tank just adds to the clutter in my opinion.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-07-2013, 12:01 PM   #6
jorgensensc
I modified the core support to utilize the donor (08 escalade) radiator and dual electric fans. They came with the engine. By doing it this way I can use stock radiator hoses and lines without having to buy other parts etc (I reused the tranny lines and tranny cooler also) or having to hunt down a radiator hose that fits correctly. I did consider moving the battery tray, however the AC line bracket off of the bottom of the tray makes the perfect spot for the leg of the surge tank to mount. I was going to move the tray anyway but my sanden AC compressor mount from dirty dingo looks like it will interfere with the air duct plumbing.
Old 05-07-2013, 04:58 PM   #7
OKGMC4
OKGMC4's Avatar
I couldn't find a factory air box I liked so I made one with fiberglass to fit.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 05-07-2013, 05:04 PM   #8
jorgensensc
I like it! I really need to learn how to work with fiberglass! Unfortunately I don't have the timeline with this build to do it before I need to get it done. Wish I did! That looks great!!
Old 05-07-2013, 05:30 PM   #9
OKGMC4
OKGMC4's Avatar
In that case you might check out air boxes from LT1 camaros. I know they are on the driver side, but don't know if it will work or not. May just have to do the junkyard crawl. The problem is that the majority of these newer tiny engine cars have tiny airboxes with tiny air inlets. It would stink to choke your new engine down.
