Craigslist Find. Thinking about buying it
Found this truck in the Oregon section. I'm really thinking about buying it. I wouldn't mind making a 300+ mile trip.
What do you guys think? http://bend.craigslist.org/cto/3706021977.html |
![]() Join Date: Mar 2012
Re: Craigslist Find. Thinking about buying it
I would go look at it before u get too excited. It could be pretty butchered. A "drag truck" built on a junk yard budget can produce a nightmare.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
He sent me a bunch of pics and it looks pretty solid and looks just like what he described.
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Be careful and don't let eagerness influence your decision. There have been a lot of modifications to that truck and might produce some headaches trying to make it good and reliable.
But, if the package the seller is offering is what you would like to have, then go for it. Good luck.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
![]() Join Date: Apr 2013
post the pics!!
![]() Join Date: Oct 2012
does it run and drive????? major plus is it does...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
This truck could be good but it could be a nightmare too. It's been kind of Frankensteined together. I would be really carefull with that caddy engine. IMO there is a reason why caddy engines are rarely used in the racing world
'67 2wd LWB 350/4speed. |
![]() Join Date: Oct 2009
Do you want a pseudo drag truck with a caddy engine and all the associated headaches that absolutely come with it? If yes, then it's probably a good buy (but also a must see beforehand). If you think you might prefer a more stock one, then don't even consider it. You have to really want a cad motor truck to enjoy this once you get it. Personally, a cad motor swap is more of a rat rod swap (sorry) and I am just not able to see 67-72 chevs lwb trucks as rat rods. This is just my opinion, but all the cautions you're hearing above and herein might make you want to be certain before you buy. There's no way to know all the pop-up headaches you're gonna experience the first time you need to make a trip to the parts store. When you tell the freckle-faced teenager behind the counter that you have a chev with a caddy motor, his computer will start to smoke...
Posted via Mobile Device |
Moderator
![]() Join Date: May 2007
That is a lot of money to pay for what is essentially a pile of parts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Wide n'Low
![]() Join Date: Jan 2007
I think I have seen this one Craigslist before, might have even been lat summer. Not saying it's not as described, but I do notice he says if parted, he wants 1500 firm for the motor which leaves only 500 for the truck.. That might not mean anything, but it may also be that the truck has been hammered more than pictures show.. For about 2K, there seems to be plenty of running driving long bed trucks in the Northwest to choose from.. and since it states stock suspension, your not gaining any (drag truck) influence there either. If you want to build a Caddy powered truck, you might be farther ahead sourcing a motor/tranny and starting with a better truck specimen. It of course all depends on what your looking for, and budget.. But at least you would know exactly what you have first hand.
Best of luck no matter what you decide.. I'm not bashing the seller in anyway, just posting my thoughts,,
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
MOVE OVER
He said it runs and that I can test drive it (if I drive 300+ miles to do so). He did mention that he replace the master cylinder thing that holds the brake fluid, put new lines in all the way to both front brakes and put new springs and all in the front as well. Only thing he did for the rear was bleed them out. I have a bunch more pics that I will try to get them to load onto here later. I just want to buy it for the engine. I already have a 70 chevy that Had a 472 caddy that blew up on my, but like mentioned above, he did say on the phone that he will part the motor for $1500. Might as well just spend the extra 500 and get the truck too. Never know what I could build another truck into.
#13 |
i really doubt the engine is putting out those numbers.... it would need cam,ported polished heads and higher comp.
#14 |
![]() Join Date: Dec 2012
Really nice looking truck man
1971 GMC Sierra 1959 GMC 100 |
#15 |
Well just talked my girl into letting me drive out there tomorrow and check it to see if what all this guy says and shows in the pics is real. In fact my girl wants to come with me and told me that we should bring the trailer just in case. I think she might buy it cause I personally haven't made a decision. Bout a 6 1/2 hour drive though
#16 |
6 1/2 hr ride, Good luck bro
Let us know if you get it
#17 |
Not necessarily to make those kind of numbers. Maybe for a chevy motor, but these caddy motors are torque monsters. My 472 caddy (before it blew up) had a big cam, ported aluminum heads, and a high rise intake with a 850cfm holley and was making 688 hp on dyno and 804 torque. But for a stock 500 like what he has in the ad, even if the numbers aren't true, I bet they are very close to the actual numbers. These engines are very impressive. You can actually run them up to 900 torque before you have to switch anything to aluminum, but of course I'm sure you would have to put nos on it. I've been talking to a company that races and builds performance parts for caddy's for about the last 4 years.
#18 |
#19 |
sounds like you have plenty of caddy motor experience - so, I'm LESS worried than I was before
#20 |
Oh please get it
![]() But make sure its not a Bull in a China shop
#21 |
I'd buy if not rusty or bent.
#22 | |
Some may frown upon what I want to do, but I like to be different and since there aren't a whole lot if any at all caddy motors out there racing, I want to be that odd ball out there. lol If all goes over well with this truck, I'm going to build the truck to raise awareness for a condition I have and hopefully make money off it to donate to my condition as well as other conditions out that like: MS, breast cancer, autistic kids and so fourth. |
#23 |
If the truck is really like what he states it to be, then I wouldn't mind spending 2k for it, but either way I'd still like to talk him down a bit.
So What would be a reasonable price that you guys would spend for it? I'm hoping I can get him down to $1,700 and still get all the extra parts. |
#24 |
Ya Marty at MTS is the man. I have a 500 with a cam, ported and polished iron heads and manifold with about 9.5.1 comp and I thing it's in the 500hp 600ft pd range
#25 |
Well looks like I'm not getting the truck OR the engine. He called me right when I was leaving (at the gas station) to tell me that things came up and since know one has officially bought it yet, that he is going to keep the engine and is selling just the truck for $800, but is willing to come down to $600.
http://bend.craigslist.org/cto/3791748521.html That is his new ad that he posted, so if anyone is interested, It's one hell of a buy. Give him $700 and get a brand new cherry picker for free at his cost which means the buyer spends $500+ for it since they get a brand new cherry picker. Some one better hope on this. I may still get the truck just for the body, but who ever else wants, go get it. lol |
