Old 05-07-2013, 07:15 AM   #1
pete63
Active Member
Mark viii fan
I did a search but couldn't seem to find exact answers. I have a 2002 5.3 and will be using mark viii elec fan. Wondering if anyone has info on wiring this into PCM? I know I will need larger relays for the power draw, but wondering if someone had a drawing how they did theirs. Also has anyone used this companies setup, is it worth the $ to go this route?
http://www.hollisterroad.com/proddet...?prod=MarkVIII
pete63 is offline   Reply With Quote
Old 05-07-2013, 08:38 AM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Mark viii fan
To be honest by the time I bought the relays and connectors, that Hollister Road set up isnt a bad deal. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-09-2013, 07:09 AM   #3
pete63
Active Member
Re: Mark viii fan
Thanks for the reply..I talked to them yesterday prob the route I am going to go
Old 05-09-2013, 09:26 AM   #4
Custom 68
Custom 68's Avatar
Re: Mark viii fan
ok I will try not to make this too confusing... lol
The computer of course controls the fan off and on and some will even control 2 fans. Mine is a 5.3 and I only have one hooked up. I dont have the diagram for the harness but it can be found, the wire for the fan go to GROUND when the computer tells it to come on. What that means is that your relay must be setup to trigger on when it is grounded. I dont remember the schematic but I do remember there must be 2 hot wires going to the relay. The wire coming from the relay to the fan will still be the hot wire.
It is not too bad but you just have to remember the relay will be hooked up different than what the normal (on the box) method. I believe most of those require a hot wire for the switching rather than the ground. This is not a special relay just any 30 amp should work.
hope that helps.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-09-2013, 09:41 PM   #5
OKGMC4
OKGMC4's Avatar
Re: Mark viii fan
I don't know how to do it with the ecm, but I did mine with a volvo two speed relay and a BMW two speed fan switch. I explained how I did it on my 5.3 here...
http://67-72chevytrucks.com/vboard/s...=368649&page=7
...with pics and wiring diagram, post 162 and 165. Thing works great, and in 3500 miles, some of it in stop and go traffic, some over 100 degree weather, and with the A/C on I still havn't had the high speed kick on yet.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
