Old 05-07-2013, 08:02 AM   #1
Elliot949
Elliot949's Avatar
ok here is a question for you guys...
I have a 67 3/4 Ton pickup... I am going to convert it to a Short wide bed 1/2T... The question I have is will the suspension from a 1/2T bolt straight onto the chassis of a 3/4t frame or what would need to be changed...
Thanks...
Dan
Elliot949 is offline   Reply With Quote
Old 05-07-2013, 10:08 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: ok here is a question for you guys...
The best way I have found is to take the whole front cradle from one frame and move it to the other with all the associated parts.
I am sure others will chime in with more info.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-07-2013, 10:15 AM   #3
bodydropped68
bodydropped68's Avatar
Thanks...
Dan
Yes it will. Swap the upper and lower control arms and steering components tie rods center link etc spindles brakes etc and bolt your 1/2 ton rear end in bleed the brakes and go.
bodydropped68 is offline   Reply With Quote
Old 05-07-2013, 10:26 AM   #4
Bomp
Bomp's Avatar
I slid a '79 1/2 ton under my '66 c20. I only had to drill two holes and it becomes obvious where to drill when installing.
Bomp is offline   Reply With Quote
Old 05-07-2013, 06:56 PM   #5
Elliot949
Elliot949's Avatar
Thanks guys... I am probably going to go with some aftermarket tubular upper and lower A- Arms and I want it to sit lower but not on the ground so maybe a 4" drop spindle...
Old 05-07-2013, 08:33 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
If you swap a 67-72 complete front crossmember and rear axle it will bolt in. 73-87 require a couple of holes to be drilled and others enlarged
WIDESIDE72 is offline   Reply With Quote
